11-28-2009, 07:01 PM | #1 |
Rep 615
Why are Z4M tires taller than 3.0si's
I'm going to order some non-run flat tires tonight to take advantage of DTD's special discount that goes through Monday. Probably getting the Hancook V12's as they have a rebate that expires soon too and have received very good reviews. I have the sport package on my coupe and was wondering why the M coupes have the same width and rim diameter as the 3.0si coupe but have slightly taller sidewalls on the tires. Does this have something to do with the fact they are non run-flats and need the extra width? Should I get the taller size for my coupe? I know it will add about 3.5% to my speed relative to the spedometer reading but I'm not concerned about that.
All comments and opinions are appreciated. Thanks.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2. Last edited by mhughett; 11-28-2009 at 10:16 PM.. Reason: circumstances changed |
11-28-2009, 11:23 PM | #3 | |
Car Geek
3626
Rep 3,594
- Very low profile tyres are more for looks than performance - Effectively higher gearing for higher speeds in each gear - Standard ///M tyres aren't sized to give the wheel arch clearance to fit snow chains (alternative OEM winter tyre size for Z4M and M3 is the same as for Z4 or 3-series, to allow chains to fit). |
11-28-2009, 11:37 PM | #4 |
Rep 815
11-29-2009, 06:14 AM | #5 |
Rep 615
I agree with the comment about the gearing ratio offsetting the change in tire diameter. What I was wondering was whether buying the slightly taller size would have a noticeable effect on the car's acceleration. I've also heard about this "3%" rule meaning that you should never change your size by more than 3%. What's up with that?
11-29-2009, 08:14 PM | #6 | |
Car Geek
3626
Rep 3,594
The 225/40-18 is the same size as used on the front of the Z4 with sport package. If you can use both a 225/45-18 or 225/40-18 on the Z4M without any modification, then you can probably do the same on the Z4. You probably won't notice any significant acceleration difference. |
11-29-2009, 08:26 PM | #7 |
Car Geek
3626
Rep 3,594
The gearing is 4.6% higher in the non-///M, but the ///M has a 14.3% redline, so with the taller tyres, the maximum speed in any gear is 13.6% higher in the ///M vs a 3.0si.
11-29-2009, 09:53 PM | #8 | |
Rep 615
By the way, I did some direct comparisions this weekend since there was a 2006 M roadster for sale not too far from my house. I measured the diameter of the wheel/tires of both cars and there was about 1/2-3/4 of an inch difference. Not a lot of difference. I really like the fatter steering wheel and this might be on my short list for Santa this year. Pretty pricey from Tischer at about $1k. Ouch. The main thing I wanted to check out is how much different the tires made in the ride over small bumps and pavement irregularities. This convinced me to dump the run-flats, NOW.
11-29-2009, 10:57 PM | #9 | |
Car Geek
3626
Rep 3,594
I would buy tyres from a vendor that promises an exchange or refund on the tyres if you don't like them or if they cause problems. All indications are that the ///M sized tyres will work without a problem on your non-///M Z4. |
11-30-2009, 08:44 AM | #10 |
Rep 615
I looked in the Z4M owner's manual (available online at BMWUSA.com) and sure enough they recommend the smaller size as well for M+S tires. I guess that is to allow for chains if necessary but I can't imagine using them on such a low-profile tire. In any event I went ahead and ordered the M sized tires and bought the Hancook V12 Evo's due to the favorable reviews they have received as well as the great incentives they have (that end today). Thanks to everyone for your help.
11-30-2009, 09:40 AM | #11 |
Rep 2,120
I'm sure it just boils down to what GP20 already said,
Leftover M3 stock, Shame they didn't fit the Michelin Pilot Sports of the M3 run But I do remember back in 06 when the E46 M3's were still in showrooms there was a 06 Vert with Conti's, and a 06 Coupe with Pilot Sports, (both with the 18" wheel), Then as we all know all Z4M's came with the Conti's (with M3 on the sidewall)
Imola Red Roadster |
11-30-2009, 09:58 AM | #12 | |
Rep 4,726
11-30-2009, 10:30 AM | #13 | |
Rep 2,120
I actually was a big fan of the first gen Pilot Sports, If you look at this pre-production Z4M you can see it has the PS's fitted to it, and a nice exhaust can setup Shame it didn't come like this
12-06-2009, 07:32 AM | #14 |
BMW Fan
11
Rep 553
BMW speedometers are notorious for displaying a speed that is higher than your actual speed. The odometer measures an accurate distance, it's just the speedometer that is intentionally made to read high. I read once that there is some German law that the speedometer must give the correct speed for the largest diameter tires than can possibly be fitted on the car. Since you ordered the M sized tires for your car, you will lose a slight bit of acceleration but you will gain a bit of fuel economy, your speedometer will more accurately indicate your true speed, and you will have a little more sidewall between your wheels and whatever road hazards they may encounter.
12-06-2009, 09:14 AM | #15 | |
Rep 7
are the new tires you bought (Hancook V12) of the Run-flat type? If not, what happens in case of a puncture? I just bought a used Z4C and it has Non RunFlats fitted. the tires are a year and a half old so i'm not considering replacing them for the next 2 years. As i see it i have two options: 1. buy a can of Tire-fix (don't know what its correct name is... ) to keep in the boot or 2. buy an emergency tire + jack any suggestions? (sorry if i'm off topic...... ) |
12-06-2009, 09:25 AM | #16 | |
Rep 615
12-06-2009, 09:52 AM | #17 | |
Rep 7
Any comments on the cans of foam spray which seal the puncture from the inside? is it true that this is a temporary solution until you reach a tire shop? and the tire must be replaced after using this foam? thanks!! |
12-06-2009, 10:01 AM | #18 |
Rep 615
It's my understanding that the tire goop is only temporary. The tire shops hate this stuff as they have to clean up the mess once they take the tire apart and put a patch in place.
12-06-2009, 12:43 PM | #20 |
Rep 4,726
Um, NEED those exhaust cans... stock ones stick out so much.... I'm probably going to paint them eventually.
12-06-2009, 01:15 PM | #21 | |
Rep 2,120
I actually just fitted the E46 M3 stock exhaust tips to my M, They are longer than the Z4M tips and look really nice, I will have to do some photo's and the cans I have seen painted flat black and it looks much better,
12-06-2009, 01:57 PM | #22 |
Rep 4,726
Any more pics of the preproduction? It looks like the side are different too, I'm glad that trunk key hole didn't make it to production though.
