      07-15-2021, 11:48 AM   #1
rsutoratosu
Drives: Z4 3.0i
z4 with m suspension
Got a question, the z4 with m suspesion, on bilsteins site, the search says to use the b8 because its lowered. B8 is stiffer correct ? is there any other solution to a softer ride ?
I guess the other option would be replace the front & back with b4 and get regular springs and swap out the M lowering springs ?
-Roranji
      07-15-2021, 04:52 PM   #2
Spec-Al
Drives: bmw
I replaced my blown m-sport shocks with Bilstein B8. The ride was noticeably better afterwards.
      07-15-2021, 08:33 PM   #3
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
I have the Msport suspension and replaced my shocks and struts with B4s, kept the original springs but upgraded all the other suspension parts. Huge difference in ride and handling.
      07-16-2021, 05:03 PM   #4
rsutoratosu
Drives: Z4 3.0i
Did your ride height change with b4 ?
-Roranji
      07-19-2021, 06:24 PM   #5
SunUpTopDown3
Backroad Warrior
SunUpTopDown3's Avatar
Drives: Z4MR
Yes B8 is valved for lowering springs, they are marketed as Sports shocks for lowering springs. They are firmer/stiffer than factory. There is also B6 which are also sport shocks and are the same firmness/stiffness as B8 but these are valved for OE springs/ride height.
B4 are touring and are marketed as direct stock/factory replacemnet. But significantly improved damping and control than factory (not necessarily stiffer)
Shocks dont usually change ride height, springs do.
      07-19-2021, 09:17 PM   #6
rsutoratosu
Drives: Z4 3.0i
Some guy at the other site says getting b4 for his m suspension raised the car.. he had to return it and get b8. So i was just confirming that..
-Roranji
