      06-28-2021, 01:00 PM   #1
kyriian
kyriian's Avatar
885
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Brake issue - an odd one
So my Z4M recently developed another little niggle
-One of my wheels show significantly more brake dust than the other wheel
-The dust pattern is only on the side to the outside, the inside is far cleaner (I have white wheels, so this is VERY obvious)
-I had replaced my brake caliper bushings, and brought a rebuilt caliper, it bled fine
-It drives fine, it does not show sign that it is pulling or a seized caliper, nor do i hear it dragging.
-BUT, the dirty wheel's rotor is defenitely hotter than the other side.
should I spend the coin to replace my 10k old rotor? What else could it be
Revolution of our Times
I will return to the track, one day.
      06-28-2021, 07:25 PM   #2
Clearancediver
Drives: 2004 Z4
Likely the piston on one side of the caliper isn't pushing onto the brake pad. The other piston/brake pad is compensating … hence the excess of dust and one side of the rotor heating up excessively.
I'd replace the rotor with new not rebuilt…
Sent from my smart phone...
