      03-24-2020, 01:53 PM   #1
CJW2OO4
CJW2OO4's Avatar
Advice Wanted for Bushing Refresh Kit (Street Driven)
Hello everyone,
I was wondering if you guys had an leads on some good bushing refresh kits?
I am upgrading my suspension and wouldn't mind doing as much as possible.
Have:
H&R Coilovers (was pleased last time i had them)
GC Front Camber Plates
Control Arms (OEM)
Tie Rods (OEM)
Sway Bar Links (Garagistic)
Front Shock Tower Reinforcement Plates (Garagistic)
Rear Trailing Arm Reinforcement Plates (Garagistic)
FCAB and Mounts (From Zposter - the fly)
Need to Buy
Rear Shock Mounts - (probably gonna get Rogue RSM)
Rear Trailing Arm Bushings
RTAB Limiter kit
Sway Bar Bushings
What else would you get / recommend?
Would you do Rear adjustable camber arms?
Any worthwhile Sway Bars I can upgrade to?
Anyone have this kit? https://www.fcpeuro.com/products/bmw...m-e46m3bushkit
      03-24-2020, 03:05 PM   #2
brendanto
brendanto's Avatar
Drives: 2005 BMW Z4 3.0
When I upgraded my 2005 3.0 roadster I installed koni yellows with Eibach springs and replaced every suspension and diff bushing with purple (street) powerflex bushings. I have been very happy with this setup for spirited street driving and no issues. I had the sport suspension so didn't replace sway bars.
      03-24-2020, 03:31 PM   #3
CJW2OO4
CJW2OO4's Avatar
I heard poly bushings can be quite noisy... was that your experience as well?
      03-25-2020, 10:42 AM   #4
brendanto
brendanto's Avatar
I didn't notice any noise - follow directions for lubricating them when installing.
      03-25-2020, 11:24 AM   #5
Steeler
Steeler's Avatar
2429
Plus 1 on the poly not squeeking or making any other noise.
Be sure to use the lubricant they provide with each bushing
      04-08-2020, 09:07 AM   #6
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
I have a full poly suspension. No squeaks here. I've had it for 2.5 years daily driven. It's a stiff ride, just lubricate properly when installing. Also, at times the fronts may need to be re-lubed. Thats something I read. I have noticed a slight squeak, but I think it's my dashboard honestly.
      04-10-2020, 04:05 PM   #7
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
By any chance do you still have a link around? I'm really curious about amount of maintenance needed and if alignment will be needed after that.
I'm in the same boat as TS slowly gathering a list of suspension parts to refresh in my Z.
But I also have a 4Runner that has poly bushings in UCAs. Man, this is a nightmare to maintain. I need to lubricate them every 5kmiles and it starts squeaking already past 4kmiles.
      04-10-2020, 06:52 PM   #8
Yapakanichi
Monkey Marshall
635
Nah no link sorry. I would strongly recommend an alignment when replacing the bushings.
It was more like you MAY need to, like it COULD happen. But thats with anything. I just went for a drive to the store and no squeaks.
      04-10-2020, 08:27 PM   #9
vt100
vt100's Avatar
126
that goes without saying
I was more curious about re-lubricating them as a regular maintenance - can it be done without removing control arms?
CJW2OO4147.50
      04-11-2020, 09:04 AM   #10
Yapakanichi
Monkey Marshall
635
Well I know that the lollipop can be removed without taking the entire control arm off. If it can be taken off it can be lubed.
But honestly, I haven't re-lubricated mine at all. I mean the entire suspension other than the sway bars is poly bushings.
      04-12-2020, 05:44 PM   #11
CJW2OO4
CJW2OO4's Avatar
anyone ever buy from Garagistic? I saw this bushing kit for the M3 and I was wondering if anyone can comment on the quality of their products or if this kit would kit?
https://www.garagistic.com/collectio...ll-bushing-kit
      04-12-2020, 11:34 PM   #12
vt100
vt100's Avatar
126
I see. Thanks.
      05-02-2020, 11:16 AM   #13
Spec-Al
Drives: bmw
Generally speaking, pretty decent quality, but I think YMMV depending on the specific part they make. I've ordered from them several times for my E30, only complaint is shipping/handling times can be a bit long as they don't always necessarily have stock on hand (and the site doesn't always reflect this) and can take a few weeks for fabrication.
      05-06-2020, 07:33 PM   #14
1messedupZ4M
Drives: 2007 Z4M, 2003 E46 M3
So, is it confirmed that all of the bushings for the E46 M3 will fit the Z4M?
      05-07-2020, 04:56 PM   #15
Spec-Al
Drives: bmw
1messedupZ4M I don't think all of them are the same. Z4M uses e36 style front shocks/knuckle, and e46 non-M front control arms. FCABs, RTABs, sway bar bushings should be same, but not sure what else. Point is I think you should probably double check depending on the bushing.
kaybat125.50
      05-07-2020, 06:27 PM   #16
1messedupZ4M
Brutal.
I was hoping to put full poly onto my fun street Z4M soonish.. Looks like I'll be collecting parts for a while before I get around to stripping it apart.
      05-07-2020, 06:32 PM   #17
1messedupZ4M
Originally Posted by 1messedupZ4M View Post
Brutal.
(double post)
someone should make a masterlist of what bushings the Z4M uses.. so people can pick which ones they want to use..
      05-27-2020, 07:10 AM   #18
CJW2OO4
CJW2OO4's Avatar
I keep accumulating parts... but I am thinking about buying OEM bushings since my car is street driven.
      08-19-2021, 10:05 PM   #19
FigureItOut
Drives: BMW Z4 3.0i
I swapped in the polyformance FCABs and the Meyle HD front control arms along with a set of BC racing coil overs. Really tightened up the front end and improved my confidence in turn-in and handling. I was worried about excessive NVH but I didn't notice any meaningful change. I've got the M-sport suspension so I retained the factory sway bars.
I'm currently investigating swapping more bushings and components over to poly to further tighten things up.
      09-08-2021, 02:25 PM   #20
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Go with OEM. I am planning a similar control arm, suspension, and bushing refresh for my car this winter - will do all lemforder or OEM. Swapping Bilstein PSS10 and Ground Control Street plates in for the outgoing KW Clubsport setup.
I have streetable track car on all poly bushings. It'll find every loose item or plastic trim rattle - not the life I want for the Z4MC
wdb4732.00
