05-12-2021, 06:53 AM | #1 |
Rep 685
Drives: 06 Black Sapphire Z4MR
Suspension Rattle
See if anyone may know what it is, it is also accompanied with vibrations at highway speeds.
I had the front end up last week, and i didn't see or feel anything's loose. https://drive.google.com/file/d/1SAG...ew?usp=sharing - 1st recording https://drive.google.com/file/d/1S9f...ew?usp=sharing - 2nd recording Anyone also know what size is the OEM front control arm hex?
Revolution of our Times
I will return to the track, one day. |
05-15-2021, 05:00 PM | #2 |
Rep 779
Really hard to tell.. the control arm the middle nut is 21mm. I had to go buy a 21mm for it. not sure about the end.. Ill go measure it in a bit..
-Roranji
05-15-2021, 07:45 PM | #3 |
Rep 685
Check your bolts on the sub-frame brace. My suspension was driving me crazy for weeks making strange noises and I found two loose bolts, fixed the problem.
https://www.ecstuning.com/b-genuine-...e/51717028433/ |
05-17-2021, 06:54 AM | #4 |
Rep 685
I took it to a shop and finally traced the issue, should have been obvious
Top nut of my coilovers came loose I had to take it off, and retighten it
