      01-17-2021, 05:32 PM   #1
MadGus
Drives: 2006 Z4MR
2006 BMW Z4MR  [0.00]
Z4MR suspension refresh
Hey folks. Swapping original front springs onto Bilstein B6s, and have a question about how to position the spring on the lower pad above the strut plate.
Here's how the spring is positioned on the passenger side, which I have copied onto the new driver's side strut.
Is this placement correct?
      01-17-2021, 07:16 PM   #2
Steeler
Steeler's Avatar
2429
If I remember correctly I bottomed the end of the spring against the stop on the isolator.
The spring coil began to rise at the step in the seat and rubber, so made sense to me to do it that way.
MadGus79.50
      01-17-2021, 08:08 PM   #3
MadGus
Drives: 2006 Z4MR
Thanks, dbarton. Do you mean that you lined up the end of the spring with where my green arrow is pointing?
When I tried pushing the end of the spring to the green arrow, the bottom rung of the coil hung over the side of the strut plate and the spring didn't want to sit down fully on the other side. Lined up as my pic shows it, it stays lined up all the way around.
kaybat125.50
      01-17-2021, 08:46 PM   #4
Steeler
Steeler's Avatar
2429
From Pelican parts diy page. Disregard the blue arrow.
Looks like the Spring is not bottomed out against the isolator stop
      01-18-2021, 05:06 AM   #5
MadGus
Drives: 2006 Z4MR
Thx, dbarton. That's exactly what my spring looked like when I lined it up that way. Guess pelican has it right (which is not a surprise)!
      01-18-2021, 11:06 AM   #6
MadGus
Drives: 2006 Z4MR
Should the new strut mounts turn freely when everything is reassembled? I was going to torque the top lock nut down on my passenger strut and noticed that the mount doesn't rotate.
Thinkin I messed something up on reassembly.
Appreciate any thoughts...
      01-18-2021, 11:27 AM   #7
MadGus
Drives: 2006 Z4MR
Never mind! Mount doesn't turn when spring is released from compression tool...
But it is important to have the mount bolts lined up before you release the spring!
      02-05-2021, 08:26 PM   #8
thielepr
Drives: 06 Z4M, 11 M3, 17 230i
How was the outcome? How do you like it?
racerbruce3853.50
      02-08-2021, 09:02 AM   #9
MadGus
Drives: 2006 Z4MR
Should have done this when I bought the car. All four old shocks could be compressed by hand with virtually no rebound!
Car handles much better now, and feels more "planted."
racerbruce3853.50
      02-08-2021, 12:02 PM   #10
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Awesome!
it makes such an incredible difference. I did this same conversion to Bilstein B6's and Eibach Pro-Kit springs in Q1 2017; I love the 3/4-7/8 in front drop and the 3/8-1/2 in rear drop; I also replaced the OEM front control arms with the high performance Lemforder ZHP performance front control arms and new OEM FCAB's and all new shock pads, guide supports, shock bump stops, etc; it is STIFF and handles like a freakin' race-kart....it is entirely flat in corners. I did this upgrade at 62K miles.
How many miles on your Z4MR when you upgraded??
Name:  Red Roadster Apr 2018 Pic 10.jpg
Name:  Red Roadster Apr 2018 Pic 11.jpg
Racerbruce
      02-08-2021, 01:08 PM   #11
MadGus
Drives: 2006 Z4MR
61k on her at upgrade... couple hundred more now. :-)
      02-08-2021, 02:43 PM   #12
racerbruce
racerbruce's Avatar
3854
Wowie!
We did our suspension upgrade(s) within 1K miles of each other.
Racerbruce
      04-14-2021, 01:27 PM   #13
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Madgus or Racerbruce, do you have the torque values for the fasteners involved in the front and rear shock replacement? I'd appreciate it if you could share. Much thanks.
      04-14-2021, 02:30 PM   #14
MadGus
Drives: 2006 Z4MR
Elerner - here's a link I found helpful
https://www.pelicanparts.com/techart...eplacement.htm
      04-16-2021, 03:24 PM   #15
elerner61
elerner61's Avatar
157
Yes thanks, I've seen that and will be referencing it for the work but there are no torque values there. From BMW Workshop Manuals (TIS excerpts) I've identified the fasteners and from another online post I found the Torque Values. Really wish that NEWTIS wasn't taken down by BMW.
31 31 1AZ Strut pivot mount (3 nuts to strut tower): 34 Nm
31 31 2AZ Strut to pivot mount (1 large nut): 64 Nm*
31 21 4AZ The three bolts to hub carrier: 81 Nm**
31 35 5AZ End links connecting strut: 58Nm
https://workshop-manuals.com/bmw/z_s...(m_r/page_895/
