04-22-2009, 11:40 PM | #1 |
(oO (||||) (||||) Oo)
Rep 165
Need help with AUX DIY
Alright, so I tried searching and tried dealers but no find.
I ordered that little brick looking AUX input that goes under the AC controls + precut piece of plastic. I also got some cable that was supposed to be good. It was a dual male. When I tried connecting it, it turned out perfect being connected to the brick and everything but the other end wouldn't fit the harness. Parts department couldn't find the piece :/ Does anyone know the part number for that little cable that will connect the AUX piece with the radio harness? Thanks for help!
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red |
04-23-2009, 06:17 AM | #2 | |
Rep 274
Drives: 2010 128i Conv.
http://www.bimmerfest.com/forums/sho...ight=Z4+Aux+in |
04-28-2009, 11:15 PM | #3 |
Rep 165
Hey, thanks but I tried and it doesn't work.
Here's the story: I wanted to do the AUX system that's found in later 07 models and up. I bought necessary parts but couldn't find the cable from AUX IN to RADIO HARNESS. I decided to buy that Z4 kit from the dealer that goes inside the ash tray compartment. Then, I cut off the wire and connected the harness piece to the wire I already had (Gray, Yellow, Blue) It turned out that 3/4/10 combination didn't work. So I decided to run 2/3/4 pin combination. It worked for a little while but then dead again. What am I doing wrong?? I'm so desperate, I'm probably gonna go to the dealership and look inside one of their cars to get part number.
04-29-2009, 06:35 AM | #4 | |
Rep 274
04-29-2009, 09:19 AM | #5 |
Rep 165
I got all the info. Also, remember that I tried modifying the original kit with the cable I already had so that it would plug into the harness.
04-29-2009, 10:34 AM | #6 |
Rep 274
I believe that therein is your problem. I suggest you start from scratch using the instruction provided and a new, compatible cable.
04-29-2009, 12:43 PM | #7 |
Rep 165
Well that won't work because I don't want to use the ashtray design aux input. I want to do it the way 2007s and up are.
04-29-2009, 02:24 PM | #8 | |
Rep 274
But, enough of this pointless dialog. Take it by the dealer. |
04-29-2009, 07:04 PM | #9 |
Rep 165
Alright, so I got the cable. The legit one and it still doesn't work. Would it be possible that because I was messing around with all that I could've fried something? I mean everything is perfect and I put both things together as well. It still doesn't work... I'm probably gonna have to take it to the dealer :/
