05-09-2012, 04:10 PM | #1 |
Rep 398
KW Clubsports & linear springs
Looking to up the spring rates on my clubsports. Called KW and they indicated that i should NOT be swapping out the rear progressive for linear. Lots to do with the nature of the suspension set-up and not being a "coil-over".
Looking for member guidance and feedback on this. Thoughts?
BSM Z4M Coupe
05-09-2012, 09:27 PM | #2 |
Rep 1,373
Did KW mention any reasons behind why they think it is bad to run a linear spring on a none coilover rear?
I am interested to know the reasons why because I would like to switch over to a full coilover rear in the future I believe The Platte Forme guys in Cali run that red line time attack m coupe with KW club sports but have substituted all the springs for Hypercoil spring
07 Z4 M Coupe AW/IR |
05-09-2012, 09:54 PM | #3 |
enthusiast
48
Rep 1,695
I would assume that it would have to do with the rebound and compression nature they designed in the strut. Different struts have a range which they work well. IE ground control and tc kline are good from 400-800 lb spring and its resisiance on a graph is linear.
It would seem that it would be difficult to go from a strut designed for a progressive spring to a linear, due to the resistance not being correct. At least if ride quality is important. You should be able to install a larger sway bar, which is progressive by nature. That might work for what you need. What are you attempting to do? |
05-09-2012, 10:43 PM | #4 |
Rep 398
seank - i'm simply trying to stiffen up the ride for the track (I plan on 2-3) and for the spirited drives up and down santa cruz hills
They specifically define the rear suspension to be progressive based on a non-coil over design. I simply did not understand this and wondered if other did as there seem to be linear rates people are running with AST and TCK etc? My target is 500 frt and 600 rr. The clubsports are surprisingly soft.
BSM Z4M Coupe
05-10-2012, 12:15 AM | #5 |
enthusiast
48
Rep 1,695
F1soul-
It sounds like you may be wanting the struts to do more than they are capable. It has to do with that particular model: the clubsports. From my understanding, they were designed to be a very street friendly design. I have not owned them. Just going off of what I have read on this forum. That type of spring rate is usually used on a coilover that is atleast single adjustable. Hopefully someone who has experience with this particular model with linear springs will chime in regarding the effects. |
05-10-2012, 05:04 AM | #6 |
Rep 2,747
I agree that the clubsport run a little "soft"
I have been looking into swift springs and like the idea of a true coilover in the rear. Most companies are running linear springs in the rear (GC, TKK, etc) and they work. I think KW may be concerned about running linear springs that are too short and could have the potential of working themselves out of position. Companies like GC, TCK, H&R and Vorshlag use different rear height adjuster, so maybe they have the safety aspect of using linear spring in the rear figured out. The other issue is noise. The progressive spring is more forgiving in the chatter department because even when the suspension is fully extended, the progressive spring maintains contact with the body of the car. her is a pic of a true KW rear coilover on a Z4. Can't find a part number for it, but there it is
05-10-2012, 11:07 AM | #7 |
1821
Rep 5,337
I would be surprised if they did that coil-over installation right. BMW didn't put in nearly enough reinforcement to allow coil-over springs to be attached to the shock tower. The ONLY way you can run a coil-over rear on the Z4 chassis without it literally punching a hole through the back side is if you weld your cage directly to the rear shock tower and reinforce the f**k out of it, so the force from the springs are spread out onto the cage structure.
05-11-2012, 03:37 PM | #9 |
Rep 1,663
I'm also interested in this topic. I previously posted a thread on Swift spring conversion for V3s. My reason is I'd like to tighten up the rear a bit, but also prevent the coils from rubbing and groaning under full compression.
If the springs are going to be chatty as crfine mentions, then it might not be a good solution. I've thought about just changing the rear shocks as well, but there doesn't seem to be anything that isn't either very loud or very expensive like mcs. I don't know about the clubsports, but the V3s have reservoirs that make replacing the rear brake pads a bit of a chore (you can disconnect from the top mount if you have one, but it would be nice to not have to).
05-11-2012, 03:49 PM | #10 | |
Rep 11,668
I've seen this attempted on other makes without proper reinforcement. The results were not pretty.
05-11-2012, 04:14 PM | #11 | |
Track Head
24
Rep 503
http://www.motoiq.com/magazine_artic...t-monster.aspx Some build details, the entire car is caged and seam/stitch welded.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning |
05-11-2012, 04:20 PM | #12 |
1821
Rep 5,337
Would have been my first guess based on that double caliper setup on the rear.
05-12-2012, 11:05 AM | #13 |
Rep 398
I found a set of KW 600lb 60mm rear springs at 5.5".
I'm going to test fit them at the same time I swap out the fronts for 500lbs. I'll post updates.
BSM Z4M Coupe
05-14-2012, 09:27 AM | #14 | |
Rep 2,747
If you run into coil chatter or noise from the rear springs, check out these articulating spring perches from rogue. I am thinking about trying these out. http://www.rogueengineering.com/rogu...SH/RE-ASP.html
05-14-2012, 01:53 PM | #15 | |
enthusiast
48
Rep 1,695
05-14-2012, 02:34 PM | #16 |
Rep 11,668
^WHS... very cool idea!
05-30-2012, 10:27 PM | #18 |
Rep 753
One thought on why the clubsport rear springs are progressive is to allow for more grip over uneven track surfaces. A softer intial rate will let the suspension soak up the undulations better while keeping the tires planted.
05-31-2012, 01:31 PM | #19 |
Rep 11,668
^sounds plausible.
06-01-2012, 12:05 AM | #20 |
enthusiast
48
Rep 1,695
Slightly off topic, unless you have wheel chatter:
 http://www.rogueengineering.com/rogu...SH/RE-ASP.html BTW. Ground Control has this same part for cheaper. I will be installing it tomorrow, as well as many other suspension parts. I will let you know how it goes. |
06-02-2012, 12:24 PM | #21 | |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
06-03-2012, 03:44 PM | #22 | |
Rep 398
Thus they created a reinforcement plate. RE actually brings these to together and is made of better materials. In my opinion the RE are much higher quality. Kudos to GC for acknowledge the need for a "weight jack" or articulating perch.
BSM Z4M Coupe
filtercoffee107.00 |
