04-03-2012, 04:13 PM | #1 |
Rep 2,737
My new custom BBK using 135I calipers!
finally got it on today! it bolted up like a dream, i even could use my stock rotor dust sheild!
picked them up off a 135I and modified the carrier and brake lines to work with the Z4M rotors, working on fabricating the rears. if anybody has a Z4M rear rotor that is trash and has not thrown it away yet please let me know, i would love to use it to make the proper attachment brakets for the rear caliper. this was as easy an istalation as an aftermarket BBK, I LOVE IT!!!! best part is the price! all parts included was just over $700 invested. it truley fit as if it was made for it! Last edited by -c-; 04-07-2012 at 12:44 AM.. |
04-03-2012, 04:37 PM | #3 |
Rep 2,737
04-04-2012, 05:53 PM | #6 |
The Wrapgician
47
Rep 354
Drives: z4si
Why not buy from ecs tuning since they got the special made carrier for you car? struggle on which one should I go for now... Nice mod! Keep update!
04-04-2012, 07:37 PM | #7 | |
Rep 2,737
04-05-2012, 08:59 AM | #11 |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.26] |
nice, u should mass produce those brackets, they'd sell really well bet here and e46 fanatics...
04-05-2012, 11:13 AM | #12 | |
Rep 2,737
04-05-2012, 11:27 AM | #13 |
Rep 5,329
i dont think these will be able to hold the performance of a well driven z4m?? ive read about the pistons cracking up numerous times...... i know OP has a 3.0l but for the guys with the ///M cars.... hmmm i not sure this would be an upgrade from what you already have...
04-05-2012, 11:42 AM | #14 | |
Rep 2,737
04-05-2012, 12:20 PM | #15 | ||
Rep 12,570
OP is correct, that was all due to someone not using the correct pad, I think it was cut to fit or something like that. The only complaint for this brake off the e82 was the small rotor but OP addressed that by using this with the Z4M rotor. |
04-05-2012, 12:28 PM | #16 |
1821
Rep 5,337
How are the carriers modified? If holes are being re-drilled to accommodate the larger overall diameter of the MZ4 rotor, then that significantly weakens the structure of the carrier.
Ideally a new bracket machined from billet aluminum would be the best solution, although that's going to cost a pretty penny.
04-05-2012, 01:14 PM | #17 | |
Rep 2,737
04-05-2012, 01:30 PM | #18 |
Rep 2,737
Also by carrier I mean the caliper carrier.
So we would have the caliper attaches to the carrier and the carrier attaches to the steering knuckle the bearing hub assembly mates right up with the Z4M rotor. Good stuff! |
04-05-2012, 11:31 PM | #19 |
1821
Rep 5,337
I would be hesitant to use that setup for serious track work or racing. For the street it might be adequate.
Only reason being that the brake components see a tremendous amount of force loaded onto them, and a lot of change in said force. Any weak point in the carrier, like where it's welded, would likely bear the brunt of that twisting and changing force. I'm not a structural engineer or metallurgist. But I would seek some serious professional opinion before I put that in a car.
04-06-2012, 05:00 AM | #20 |
Rep 5,329
on my AP racing setup the the carrier is MASSIVE and i mean massive.... keep an eye on where they are welded.... this doesnt seem like the best solution..... see the grey pieces in front of the caliper.... as i said, very very beefy and nearly half the size of the massive caliper.....This is a critical part of the caliper... When im standing on my brakes @ 110mph, i NEED to know im going to be able to stop.....
04-06-2012, 07:03 AM | #21 |
Rep 2,737
Ok I'm going to have to pop a pic in here as its not as seriouses as you guys are thinking. All it is, is a round disk 5 mills thick that's welded on one part of the carrier that spaces the caliper out far enough so it properly works with the rotor. The stock steel carriers are probably stronger as any aluminum carrier. Trust me guys this isn't as bad as I think you think it is
Just like some add a spacers on your wheels I just added one on the caliper. It's no different than many custom brake setups with custom carriers, like I said earlier it's probably stronger now than it was before as soon as I can I'll post a pic. And either way since my car is an auto I don't think it will see a track or anything, different reasons I'm doing this anyhow. Need to fill in the gap lol.... |
