      08-29-2015, 12:23 AM   #1
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Vanos elimination kit, Achilles
Hi guys, anyone know anything about this kit?
Sooner or later my vanos will need a core exchange, and was wondering how this does the same job as the vanos?
Powered by
      08-29-2015, 09:48 AM   #2
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Vanos elimination kits would be useful if you are planning to run LONG duration cams (like 304/296), and don't care about loss of low end torque.
It makes sense in race applications, as you are trying to ultimately build as reliable a motor as you can (thus eliminating possible points of failure like VANOS) while maximizing high RPM power.
for a street driven car it doesn't make too much sense given the drawbacks.
      08-29-2015, 10:14 AM   #3
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks for the tech lesson, much appreciated.:-)
Powered by
      12-10-2015, 10:07 AM   #4
Bossdog
Bossdog's Avatar
27
Drives: 2006 Z4MR Imola Red
Are there any tell-tale signs of a Failing vanos?
Noise, performance change? What should I be looking / listening for?
Thanks
      12-10-2015, 10:31 AM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10871
Drives: Z4 3.0i ESS TS2+
It also requires stand alone ecu. (but when racing one's probably using that already)
      04-15-2016, 03:31 PM   #6
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
you will start hearing noise from the front almost like a timing chain rub sound....it will only get worse
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      04-15-2016, 04:29 PM   #7
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
I'm pretty sure you can tune the msv70 to run with locked vanos. It has a limp mode for a vanos failure so start there. I don't think there is much a good tuner can not do with this DME.
I would not do it, cheaper to fix the vanos.
