12-23-2015, 06:58 PM | #1 |
Rep 2
2005 z4 No power from battery at all.
I just did the battery, starter and alternator about a week ago. Car ran fine for a few days and then all the lights on the dash came on and it limped home. Now there is no power and the battery is showing a full charge on my meter. I looked on the negative cable and my car doesn't have the ibs. Where do I need to start to look.
12-26-2015, 09:45 AM | #2 |
Rep 758
How are you determining the battery has a full charge with your meter? Are you just looking at the no load voltage? It should be above 12.5 but it will hold at that voltage until you near the end of capacity.
Check the voltage at the battery with the engine running. It should climb up to 13.5 volts minimum, but 14 is ideal. If you don't see the voltage increase when you have the engine running, your alternator either isn't putting anything out, or you lost connection to it. If this is the case then you've been running off the battery and it discharged enough that it's loaded voltage fell below a level that allowed reliable operation of the electronics.
Top Down 365
12-27-2015, 12:18 AM | #3 | |
Rep 162
Drives: 2008 Z4 3.0si Coupe
2008 Z4 3.0si Coupe
12-27-2015, 10:28 PM | #4 |
636
Rep 3,124
