12-22-2015, 08:09 AM | #1 |
Rep 904
Show us your lug nuts
I just installed some Blox Racing lug nuts, so I'll go first. They stick out a lot further than I thought they would, so I'm not loving the look. I have a 75mm studs with 5mm spacers all around. What do you guys think?
12-22-2015, 08:57 AM | #2 |
Rep 11,667
It really depends a LOT on the style of wheel you are running and the lug nut used.
E.g. Mine are deeper dished and have deeper centre section. I'm also running longer lug nuts (kics r40) that cover more of the stud. My studs are 90 mm
12-22-2015, 09:04 AM | #3 |
Rep 904
I didn't expect mine to stick out this much with only a 75mm stud. Yours is good even with a 90mm stud, but I suppose that's because your wheels are concave. Maybe I just need new wheels
12-22-2015, 09:07 AM | #4 |
1621
Rep 4,294
75mm studs with locknut and a spot of blue locktite. LOVE IT!!! Far out Twixy, maybe different nuts would work? looks like your nuts are coming past the end of the bolt? (you know you wasted a perfectly good thread title here right? )
Powered by |
12-22-2015, 09:41 AM | #5 | |
Rep 904
The inside thread of the nut actually ends where the hex shape ends on the outside. I guess they are extended for the looks but I don't particularly like the look. I can get used to them, since I don't feel like spending another $100 on a new set of nuts (there. i said it). Yes, I realized that as I was typing it so I added "lug" to the title |
12-22-2015, 09:42 AM | #6 | |
Rep 11,667
It's the nuts that are poking out, not the stud. I agree, shorter nuts would definitely help.
12-22-2015, 10:07 AM | #7 |
Rep 5,327
i have turner bullet hex heads, 75mm and the absolutely gorgeous KICs R40 composite nuts.
Had this combo for years now and it still looks brand new, the nuts themselves are beautiful. haven't got a very close up pic of them but will grab one next time I'm in the man cave!
12-22-2015, 10:17 AM | #8 |
Rep 2,665
Just a question but besides making it slightly easier to change wheels, is there any real purpose to these? I am not a fan of how they look but this is just my opinion (and everyone has one).
12-22-2015, 10:25 AM | #9 | |
Rep 904
1) looks (everyone has a different opinion) 2) easier to change wheels 3) can accommodate a larger variety of spacers and wheels vs having a different set of lug bolts for every set of wheels you have and/or every time you get new spacers. |
12-22-2015, 10:30 AM | #10 |
Rep 904
I have a new thought: my lug nuts are forged AL7075 magnesium alloy. Can I just cut off the extra non-threaded cylindrical section at the end with a circular saw using a blade like this:
http://www.homedepot.com/p/Avanti-7-...128R/202021701 |
12-22-2015, 10:44 AM | #11 |
1621
Rep 4,294
Byron, are those Tunrner bolts, Apex rebranded? they look identical to mine, as do the nuts. (btw, man, be careful with those nuts, those butt jockeys at garages with their air tools love to wreak them will ill fitting sockets) I've had to replace 5 nuts before i saw what the idiot was doing… (he was looking at me like i was crazy.. well maybe i am.. a little… )
http://www.apexraceparts.com/apex-pr...l#.Vnl-aFY54lI will cost ya around 50 bucks and you get free shipping.. or if thats too steep, maybe a hack saw and a grinder.. but when you take the time to do that, you may as well fork out the 50 bucks… imo..
Powered by |
12-22-2015, 11:19 AM | #12 | |
Rep 758
Top Down 365
12-22-2015, 12:09 PM | #13 | ||
Mechanical Engineer
96
Rep 1,025
12-22-2015, 12:21 PM | #14 |
Rep 904
If it's the offset of the wheel, then a bigger spacer wouldn't help in my case, right? I may just order some regular lug nuts like what Vanne did.
12-22-2015, 12:50 PM | #15 | |
Rep 5,327
The kics stuff is very high quality and has really proven itself over the years. They have a rotating colar so they Tq down really nicely, they also look as cool as hell which is nice!
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 12-22-2015 at 01:12 PM.. |
12-22-2015, 12:55 PM | #16 | |
I plead the 5th.
523
Rep 1,519
Also, for future lug nut purchases I would personally recommend going with steel. Steel is much more durable than alum, alum being softer. I would guess steel lug nuts would hold up better for a greater number of heat cycles & installations. Alum is okay (I've had alum Rays Duralumin extended nuts in the past) but once I went steel, I don't think I'll go back
-Matt
12-22-2015, 12:59 PM | #17 | |
I plead the 5th.
523
Rep 1,519
-Matt
12-22-2015, 04:32 PM | #18 | |
Rep 758
The spacers you have are already causing some of what you see because they move the contact face in the counter bore of the wheel farther outboard which in turns moves the lug nuts farther outboard when they make contact. A thicker spacer will push them even farther out.
Top Down 365
12-22-2015, 06:52 PM | #19 |
Rep 1,001
I have a set of *Mach Schnell*and didn't want to install them because the fronts are sticking out way too far. I think my set are 75mm so i might try to get the 45mm for the fronts.
12-22-2015, 07:51 PM | #20 |
#dubspec
6328
Rep 5,200
great looking wheels. love the change
12-23-2015, 05:57 AM | #21 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
Apex 75mm studs and muteki st40 lugs
12-23-2015, 07:47 AM | #22 |
Rep 904
