      09-08-2009, 02:07 PM   #1
kmrbmw
kmrbmw's Avatar
Drives: 07 M coupe
Exhaust Installer recommendations, 4 my Z4 M. in the NYC / Westchester area.
I would really appreciate any advice you can give regarding getting my new RPI exhaust that I need installed on my 2007 BMW Z4 M coupe. I live in Westchester, (Tarrytown) 10706 Zip. Any recommendations through experience
- Can I just take it to a mavis / mineke and get installed.
- How much should this cost ?
Thank you
      09-10-2009, 12:44 PM   #2
Denverbrit
Drives: Z4M Coupe - Interlagos Blue
I had my RPI exhaust installed by a local shop (actually a ferrari dealership) because I too was worried about my own mechanical skills and the car being looked after properly. However having seen how easy an install it is, I would now do it myself without a second thought. There are just 4 bolts to tighten when installing each side.
The shop had not actually aligned the height of the exhaust tip on the drivers side quite right (was ~5 mm too low) and told me that it was a problem with the exhaust hangars. So I sent an email to Eloy at RPI about what I thought was a problem with how the drivers side ehaust had been made. Turns out that the flange on the front end of the exhaust (where it connects to the stock mid section) has a domed shape that allows adjustment of the exhaust tip height. So I put the car up on a couple of ramps last night and sure enough it was easy to loosen the two connecting bolts and get the exhaust tips heights just right. Excellent design and great technical support from RPI. I can tell you you're going to really like your new exhaust.
'06 Z4MC, Interlagos Blue, Premium pkg / extended light sepang leather, wood dash, BMW stb, Volk RE30 Formula Silver Limiteds 19 x 9 F et38 / 19 x 10 R et25, Nitto NT05s 245/35 F / 275/30 R, RPI GT exhaust.
      09-11-2009, 08:34 AM   #3
kmrbmw
kmrbmw's Avatar
Drives: 07 M coupe
Really great Info
I love that a ferrari shop cant even do it right, sometimes you just have to do urself.
Thank you very much and have a great weekend.
Mike
      09-11-2009, 10:13 AM   #4
3002 tii
3002 tii's Avatar
2286
if u dont mind making a trip out to northern nj (10 mins from GWB), check out bergen imports in cliffside park. ask for harry, and say daniel with the silver z4 sent ya. he'll take good care of u and their shop does really good work.
Follow for latest mods
      09-11-2009, 12:03 PM   #5
kmrbmw
kmrbmw's Avatar
Drives: 07 M coupe
thats perfect , i live right next the GWB
thanks
