08-15-2022, 03:34 PM | #1 |
Rep 781
Non working inner headlights
Apparently because I have bi-xenons the inner 2 headlights don't work,
has anyone found a way to add a working bulb behind those lens and add that extra light to the high beam circuit? Thanks
2008 E86 M coupe
08-15-2022, 05:00 PM | #2 |
Rep 2,547
I did look into it, there is a reflector behind the dummy projector. The dummy projector consists of a solid black fake projector lens with a translucent blue lens for the angel eye to shine through, I assume to make it look less yellow. The problem is, there's a one piece chrome surround in front of for both the dummy and real projector, but the hole for the dummy side is smaller than the reflector behind it, so I imagine the light pattern would be pretty screwed up. With the angel eye bulb holder removed, a H7 bulb drops right in, but there's no retainer, so something would need to be fabricated to hold the bulb in place.
I have extensive experience with the facelift Bi-Xenon headlight assemblies for the E85/E86 since I was retrofitting dual angel eyes using bright LED rings as a service. I used a damaged headlight from a wrecked car to prototype the dual angel eye retrofit before I went into production. Bottom line, for me, adding a high beam in place of the dummy projector would be more trouble than it's worth, though if you want to tackle it, I'd be very interested in how you accomplish it. |
08-15-2022, 08:00 PM | #3 | |
Rep 781
I could also use couple of the new LED headlight bulbs and try something, yes, a lot of work and as you say, probably not worth the effort. I just wondered if there was a popular off the shelf remedy. So you market an angel eye kit?
2008 E86 M coupe
08-15-2022, 09:15 PM | #4 | |
Rep 2,547
Also, the internals of the headlights auto-level with a motor so it's not so simple to modify them. If you really want to replace the dummy projector with a real light, a better option would be to put a dedicated LED high beam projector in there, though mounting it would take some modifications. If you simply want better lighting than the stock Bi-Xenons, replace the current projector with something like a Morimoto EVOX-R 2.0 Bi-Xenon projectors along with better bulbs which will have much better light output than the stock projectors, plus be 100 times easier since they'll bolt right in place of the stock projectors. No, I don't market a kit. |
3002 tii2284.50 grannyknot951.50 |
08-15-2022, 09:17 PM | #5 |
Rep 12,565
That last paragraph by pungo is exactly what I did and it was easily one of the best bang for buck mods. Makes the light output more in line with modern led cars.
