07-31-2022, 03:23 PM | #1 |
Rep 781
Where is the oil temp sensor?
There's an oil pressure gauge in the cluster but I have been through Realoem and I can't find the oil temp sensor, all I can see is the oil pressure switch #12
Thanks
2008 E86 M coupe
07-31-2022, 03:55 PM | #3 |
Rep 781
That is the oil level sensor, #12 in this diagram too.
2008 E86 M coupe
07-31-2022, 04:36 PM | #4 |
Rep 2,704
*I understand you have an S54*
From what I understand having done research on the M54. The oil level and oil temp sensor are combined in the bottom of the sump. I bought an aftermarket filter cover with sensor provisions for temp and pressure. https://store.vacmotorsports.com/vac...s54-p1065.aspx There are threaded bungs in the block that access the oil galleries for sensor locates also. Or you could tee off the existing sensor hole on the OFH.
grannyknot951.50 |
07-31-2022, 05:07 PM | #5 |
Rep 781
Ah, thanks Steeler, makes sense. My apologizes Clearancediver, you were right.
Here's a nice little gadget that will solve my problem, voltmeter, oil pressure and temp, coolant temp. https://blackstarmanufacture.com/produkt/multigauge/
2008 E86 M coupe
