      07-31-2022, 04:28 PM   #1
wghorne
wghorne's Avatar
Drives: 2006 BMW Z4 3.0si
Exclamation 2006 3.0si manual won’t start
I’ve had my car for a year and it’s at 99k miles. The car has run great and been maintenance free. For the last month or so I occasionally had a delay in the ignition sequence. When I turned the key there would be a second or 2 delay, with a little bit of a “whir” noise before turning over. Today, all I get is that “whir”. Lights and radio come on, but no crank.
It’s almost a daily driver and I don’t think it’s the battery, as it’s been on a trickle charger just to be sure. My educated guess is the starter, but maybe the ignition switch. Any thoughts out there?
Thanks.
      07-31-2022, 06:54 PM   #2
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Check clutch pedal height, might be too high. Just turn the stop on the floor down some.
      07-31-2022, 09:39 PM   #3
wghorne
wghorne's Avatar
Are you saying the clutch pedal isn’t down far enough to engage the starter?
      08-01-2022, 10:23 AM   #4
Our03z4
Correct, it's a safety switch. Just turn the black knob down some and see what happens. I use to keep mine right below the switch kicking in for faster shifts. But this is what happens sometimes. Takes 10secs to check.
      08-01-2022, 10:34 AM   #5
wdb
dances with roads
wdb's Avatar
4732
You should be able to hear the clutch switch 'click'. I'm deaf and even I can hear it!
kaybat125.50
      08-01-2022, 12:20 PM   #6
Our03z4
I never could hear the one on the roadster but I do work around loud equipment.
      08-01-2022, 04:35 PM   #7
wghorne
wghorne's Avatar
Wow. You guys are awesome! Just checked and seems to be working. Thank you.
      08-01-2022, 07:33 PM   #8
Our03z4
Glad we could help! They are pretty good cars that just have some quirks.
