      07-31-2022, 03:23 PM   #1
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Where is the oil temp sensor?
There's an oil pressure gauge in the cluster but I have been through Realoem and I can't find the oil temp sensor, all I can see is the oil pressure switch #12
Thanks
2008 E86 M coupe
      07-31-2022, 03:51 PM   #2
Clearancediver
Drives: 2004 Z4
Bottom of the oil pan has a sensor. Need to take subframe off to access
Sent from my smart phone...
      07-31-2022, 03:55 PM   #3
grannyknot
grannyknot's Avatar
952
That is the oil level sensor, #12 in this diagram too.
2008 E86 M coupe
      07-31-2022, 04:36 PM   #4
Steeler
Steeler's Avatar
2429
*I understand you have an S54*
From what I understand having done research on the M54. The oil level and oil temp sensor are combined in the bottom of the sump.
I bought an aftermarket filter cover with sensor provisions for temp and pressure.
https://store.vacmotorsports.com/vac...s54-p1065.aspx
There are threaded bungs in the block that access the oil galleries for sensor locates also.
Or you could tee off the existing sensor hole on the OFH.
      07-31-2022, 05:07 PM   #5
grannyknot
grannyknot's Avatar
952
Ah, thanks Steeler, makes sense. My apologizes Clearancediver, you were right.
Here's a nice little gadget that will solve my problem, voltmeter, oil pressure and temp, coolant temp.
https://blackstarmanufacture.com/produkt/multigauge/
2008 E86 M coupe
