01-16-2015, 08:45 AM | #1 |
Mess Deck Commando
244
Rep 807
Third Brake light replacement
Need to replace the third brake light on my E85. I've read a number of threads regarding proper replacement protocols. Some suggest also replacing the fasteners and springs.
To those that have replaced theirs, how did you? Thanks. |
01-16-2015, 10:17 AM | #2 |
Rep 847
I replaced it twice on my 2003 MY, and switched to the new springs the second time. Apparently earlier models had the wrong spring tension that would put too much pressure on the light causing the lens to crack.
The part numbers for the updated springs and washers are: 63 25 6 900 698 (spring x3) and 0711 9931105 (washer x3). |
01-20-2015, 10:21 AM | #6 |
Mess Deck Commando
244
Rep 807
Replaced mine this weekend. All new fasteners and springs. Finger tightened. I removed both access plates to get a better view of how the springs were compressing while I tightened the fasteners. Only time will tell.
01-20-2015, 02:35 PM | #7 |
636
Rep 3,124
Mine was cracked all around the edges and then finally cracked across the center.
New one started cracking at the top edge within a week. And this was with the weaker springs. Went to Lowes and got nylock nuts (M4, IIRC) and put them on about 1/2 way. That was several months ago. No new cracks. No leaks, yet.
01-20-2015, 08:07 PM | #8 | |
Mess Deck Commando
244
Rep 807
When you say "half way," do you mean right at the point of the shaft where the nylock nut meet the spring? Or do you allow some compression of the spring? |
01-21-2015, 03:03 PM | #9 |
636
Rep 3,124
About 1/2 way down the threaded portion of the shaft, so there's some compression, but not full.
I tightened the nuts evenly, a little at a time, until the assembly stopped wiggling.
01-22-2015, 08:39 AM | #10 |
Mess Deck Commando
244
Rep 807
01-22-2015, 09:08 AM | #12 |
Rep 847
01-22-2015, 09:16 AM | #13 |
Rep 1,991
01-22-2015, 09:57 AM | #14 |
Rep 847
I think his issue is not the common spring tension problem that affects early MYs. The bulletin on the common problem came out in 2006 IIRC, so they should have corrected it prior to that.
01-22-2015, 10:06 AM | #15 |
Rep 4,057
My car is a 2006 as is Chickdr's car, and mine did this in the last year of warranty, after which I had the light replaced. That is four years ago now and it has been fine since.
Huz-Z
01-22-2015, 08:36 PM | #17 |
Mess Deck Commando
244
Rep 807
For the record, this is my third replacement in the car's life. I believe the most recent (second) replacement was not properly installed. Looks like the tech used the OE (as the one from South Carolina) when he replaced the third brake light over two years ago.
01-22-2015, 10:51 PM | #18 |
636
Rep 3,124
Yea, I have no idea what my problem is.
Could be thermal cycling in the California sun. Could be vibration from the drone of my RE exhaust.
