02-03-2011, 03:18 PM | #1 |
Rep 39
335i Coupe SPORT OEM STYLE 189 wheels for 2006 Z4 3.0si?
Does anyone know if 2008 E92 335i Coupe SPORT OEM STYLE 189 wheels & Runflat tires would fit on a 2006 Z4 3.0si?
02-03-2011, 03:34 PM | #2 |
Rep 12,565
they should fit, i had the 328i sport wheels (style 197) fit on my 07 3.0si. the stance was great because their offset is slightly more aggressive than ours. if you can find out exact width and offset, we can verify. but make sure the tires are oem z4 fitment as e90 might be taller/wider (not sure).
02-03-2011, 03:38 PM | #3 |
Rep 39
Thanks for your help!
I am not an expert, but here is the link to the posting. Maybe it makes sense to you? http://www.bimmerfest.com/forums/sho...d.php?t=512124 |
02-03-2011, 03:58 PM | #4 |
Rep 12,565
225/40 and 255/35 are the same tire fitments for z4, you will be fine (especially if you're on stock suspension)
02-03-2011, 04:11 PM | #5 |
Rep 815
Actually I think some folks with sport package suspensions have had some rubbing issues up front with E9x rims. The 34/37 offset will sit these rims 1/2" further out than the 47/50 of the OEMs. I agree that a stock non-sports-package suspension should work, but I'd want to check them out on my car before buying...
02-03-2011, 04:16 PM | #6 |
John 14:6
59
Rep 588
They will fit! Same as the 197s and I'm running 265s in the rear...and my car is dropped.
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
02-03-2011, 04:20 PM | #7 |
Rep 39
Thanks again.
I have sport button on my 3.0si but not the bucket seats. Can you tell based on that if I do have the sport package or not? Sorry just bought the car used and the wheels were changed to 17 inch ones from the regular 3.0i |
02-03-2011, 04:26 PM | #8 |
John 14:6
59
Rep 588
Sport package (suspension) or not, they will fit. Believe me, my car is dropped and I have no issues with rubbing with 265s...I may even consider adding a 10 mm spacer.
02-03-2011, 04:41 PM | #9 | |
Rep 12,565
I'm running 8.5" with offset of 30mm on 255 and no rub. |
02-03-2011, 04:59 PM | #10 |
Rep 409
this is in the front???
maybe rear instead? if it is the front... holy smokes!
02-03-2011, 05:14 PM | #11 | |
Rep 12,565
my fronts are currently 8.5" with 42mm offset on a 225/40 but i plan on changing to a 255/30 up front too once these wear down. |
