      09-21-2012, 04:17 AM   #23
marksdesigns
Marksdesigns
marksdesigns's Avatar
Drives: BMW Z4
yeah they are ok, its subjective and each of us has their own pref!
def look good when you have the Alu dash trim etc.
THE CORPORATION
      09-21-2012, 03:30 PM   #24
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Your CF looks killer with the CF leather dash, it's a great combination
      09-22-2012, 10:19 AM   #25
marksdesigns
Marksdesigns
Drives: BMW Z4
Cheers mate!
THE CORPORATION
      09-23-2012, 04:34 PM   #26
IN10SS
Drives: 2007 Z4M Roadster
I think both of the styles look good! CF is out of my range, though. I have the wood trim, so I don't think the graphite would coordinate well either. I would hate to replace the stock ones and have this happen again. Would either of the guys who did the plastic dip stuff be willing to post a picture? Thanks!
      10-10-2012, 03:15 AM   #27
marksdesigns
Marksdesigns
Drives: BMW Z4
have you heard of HYDROGRAPHICS? its that process where they can dip your part into a water tank with a graphic image on the surface etc - basically with a smooth surface to your wheel inserts you could get wood, gloss black, CF, whatever youwanted - you can even use your own graphic! really cool. Even seen alloys dipped in this way. Might be another option... hmmmm
THE CORPORATION
      11-28-2012, 02:13 PM   #28
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
After the coating wore off and after numerous paint coverings wore off, then after a set of rather cheap looking 'graphite' covers, i decided to CF mine... see pics below, expensive but now i LOVE looking at the wheel!
Where can I buy this stuff?
      11-15-2017, 12:05 PM   #29
Nordgeist
Nordgeist's Avatar
33
Drives: 2006 BMW Z4M Roadster
2006 BMW Z4M  [7.00]
Here here! I'm looking for a replacement as well, this looks brilliant. Where is this available from?
      02-12-2018, 10:37 PM   #30
RossBMWZseries
I’ve been wanting this for years. Only place I’ve seen it is in EBay for about ~$600.
      02-12-2018, 11:48 PM   #31
ANILE8
ANILE8's Avatar
No_Country
180
I got sick of waiting too.
Had mine at my local panel shop sprayed in black 2pac, been like this for over 5 years now with no visible wear, it is extremely durable! I think it cost me a couple of hundred bucks to prep and spray everything but it was well worth it as it will outlast the factory finish.
You could even get it done the same as your body color if it is to your taste.
      03-29-2018, 04:07 AM   #32
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
For anyone that has removed the trim without removing the airbag, were the steering wheel controls connected to anything when the trim pieces came off? Or did they freely come away.
      03-29-2018, 12:57 PM   #33
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
If I remember correctly, you have to remove the airbag to get to the connectors to remove the button controls. Airbag is rather easy to remove, I was surprised at how easy. Just be sure to unplug your battery.
Steve
      03-29-2018, 06:42 PM   #34
FD3S
Drives: BMW Z4M
Styling and color are rather subjective, but I don't think the graphite spokes are cheap looking.
Where can you buy those? Thanks.
      03-30-2018, 03:02 PM   #35
antennahead
https://www.turnermotorsport.com/p-5...uine-bmw-part/
https://www.ecstuning.com/b-genuine-...r/32346765626/
Both state April 23rd for shipping, my guess is they are coming from Germany.
FD3S69.50
      04-03-2018, 12:39 AM   #36
Polarbert
English Member
25
Resprayed them today with plastikote. Not a perfect job but a lot better than they were. Hopefully lasts okay.
      07-18-2018, 11:16 AM   #37
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
I just wrapped in same color film and it looks even better than original one
      07-20-2018, 02:09 PM   #38
gpraceman
gpraceman's Avatar
Drives: '06 Z4 ///M Roadster
Here's the before and after on my steering wheel spokes. I scrapped off the degraded coating with my fingernails and a wet scotch brite pad, leaving the glossy black plastic. I liked that look, so I simply left it at that and remounted them.
I did have to replace the button group on the left, as the underlying plastic was white. That and someone looked to have touched it up with some black enamel brush on paint (a pretty poor job at that). The one on the right has just had the coating cleaned off of it.
I popped out the air bag, but did not disconnect it. That gave me access to remove and reinstall those pieces. I did, though, disconnect the battery.
For the driver's side window button switch cover, I did end up painting it, as it was a bit scratched up. A previous owner probably had long fingernails. I cleaned off the coating as with the steering wheel pieces, fine sand with 600 grit wet/dry paper, paint with Dupli-Color paint+primer, then coat with a matte UV resistant clear coat. The Dupli-Color paint+primer indicates that it is formulated for plastics adhesion.
2006 Z4 ///M, Interlagos Blue/Beige
2006 Z4M Interlagos Blue/Beige
      08-30-2018, 12:12 PM   #39
ShawnPaul
ShawnPaul's Avatar
Drives: 2007 Z4M Coupe
I just rubbed it all off while it was on the steering wheel. Microfibre cloth and a lot of time rubbing. But looks new and costs $0.
      10-19-2018, 07:36 PM   #40
elliswyatt
Drives: 2021 M240i 6MT, 2016 Mk7 GTI
Looks really good. In all seriousness, would you mind elaborating on the exact method of rubbing? Did you use your fingernail to sort of push the coating off the plastic of just pressure of your finger underneath the cloth? Did you have to touch up the plastic in any way after you were done?
      10-29-2018, 08:22 PM   #41
elliswyatt
Mine look like ShawnPaul's now. Several hours of elbow grease using a microfiber towel doused in Simple Green did the trick. Very happy with the result.
      11-21-2018, 11:09 AM   #42
AK72
AK72's Avatar
M steering completely redone
Professionally re dyed M steering wheel now with combination of silver and black vinyl wrap, let me know your thoughts
kaybat125.50
      01-09-2019, 09:16 PM   #43
328skidpad
328skidpad's Avatar
49
Drives: 328xi e350 Z4M X3 M40
cheaper option.
i used 3m 1080 carbon fiber wrap, was very easy as you can use a hair dryer to mold it easily, amazon sells it for like $11 for 2 sq ft
will post pics
i sprayed the buttons with clear coat to make them shine, looks great...
StickMon636.00
      01-11-2019, 08:56 AM   #44
mziggy16
Drives: '07 Z4MC, '01 911 C4 Cabriolet
I did the removal, sand and spray. Didn't touch the airbag. It was a pain to get the pieces off, sand them and spray them. I cracked a few of the narrow parts and had to glue/sand them. Probably better to just do the rub method and leave them on.
Turned out well though.
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
