      11-07-2008, 02:55 PM   #1
PKL
PKL's Avatar
848
Drives: 2020 M4, 2022 X6
'07 M Coupe - Tire Pressure light WON'T CLEAR
Hey guys,
First of all, I DO know the procedure for "resetting" the tire pressure monitor.
I had an '05 M3 and an '06 M3 and when doing wheel swaps I was able to clear the Tire Pressure Light on the dash no problem.
My new M Coupe will NOT stay reset. Now I'm seeing something that I haven't seen before, it will actually blink for about 20 seconds and then stay on permanently. I'm getting really frustrated.
What do I do???
Thanks.
      11-09-2008, 10:17 PM   #2
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
Did you have this issue with your old wheels or did it just start with your new wheels? Did they install new TPMS units in you new wheels? If so, you may have a bad one. Chuck I
      11-10-2008, 12:44 AM   #3
chris719
Drives: '08 M Roadster
Happened to me once, I had to shut the car off for a while and then I think it went away after I drove a few miles. I did hold the button to reset and it just kept coming back, but I checked pressures and I knew they were in range.
      11-10-2008, 05:07 AM   #4
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
Originally Posted by PKL View Post
Hey guys,
What do I do???
Thanks.
Is your car an 06 or an 07? It makes a hell of a difference. Do a search on Bimmerfest in the z4 section. You will find the answers that you need.
