02-04-2012, 06:11 PM | #1 |
Rep 31
Black OEM Font Lettering
Does anyone know where I can find the \'Z4\' and the \'3.0 si\' in a black finish vs the standard chrome?
02-04-2012, 06:38 PM | #2 |
Rep 556
Drives: 2003 ESS TS1 Z4
No one makes em :-( I've asked. The closest I've gotten is from here:
http://www.jlevistreetwerks.com/3-Se...duct_info.html
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
02-04-2012, 07:38 PM | #4 |
Rep 2,747
I would paint them:
1 light sanding 2 primer 3 tack cloth 4 base coat 5 tack cloth 6 final coat 7 tack cloth 8 clear coat Doing this should yeild an OEM apperance
02-04-2012, 07:50 PM | #5 |
Rep 556
This!
02-07-2012, 02:44 PM | #6 |
Rep 31
Drives: 2005 Z4 3.0i
I actually painted my own as well, after looking, unsuccessfully, for a company that sells them
02-07-2012, 07:56 PM | #9 |
Rep 31
I believe I used Rustoleum primer, satin, and satin clear coat (for plastic). And as crfine88, do that process. Additionally I would say, make sure its a relatively warm day, and spray the clear coat on lightly or you'll probably come out with a bubbly mess
Some other items, goo gone gel and dental floss worked well to remove the emblems. I had to be careful with the 3.0 a the dot connecting the 3 and 0 makes it quite flimsy. Also, you'll need new 3M automotive adhesive tape. |
