01-02-2011, 10:48 AM | #23 |
Rep 969
It depends where the source is measured from. If you are measuring it right at the tailpipes vs. a number of meters away it would change your resulting power level. This can be seen via the sound wave equation. It becomes more complex than that.. but perhaps the moral of the story is unless they don't specify a reference measuring point, there is some 'grey area' and it may not be a specific SPL number. Keep in mind that every 3 dB is equal to twice the power.
Just an FYI: dB is not unit of measure - it's unitless. You want SPL (Sound Pressure Level) in dB relative to some reference point (often 20 micro Pascals). dB just means the measurement is in a logarithmic scale and is a ratio of the measured level relative to your reference point.
911 Carrera project car
Previous: E92 M3 ZHP - Sold E86 Z4M - Sold E36 M3 - Sold Last edited by fitchesbass; 01-02-2011 at 10:57 AM.. |
01-02-2011, 10:56 AM | #24 | |
Rep 969
Previous: E92 M3 ZHP - Sold E86 Z4M - Sold E36 M3 - Sold |
01-02-2011, 11:26 AM | #25 |
///M-fanatic
193
Rep 3,885
Hah yeah. Laguna Seca's sound check hut is located on the righthand side of the track between turns 5 and 6, approximately 60 ft. away.
Prior to headers, I could go WOT and make the 92dB cut. But after headers, I registered @ 96dB. I then had to drive by and lift off nearby the hut on the lefthand side of that portion of track just to register a lower sound. |
03-29-2011, 04:18 PM | #26 |
///M-fanatic
193
Rep 3,885
Just an update. With the following setup, I registered at 102dB from about 60ft. away @ WOT on Laguna lol
- JVT headers - SS uncatted section1 - OE section2 - SS Race mufflers My SS section2 (x-pipe) is coming in a few days So it'll probably bring me up to 105dB or something like that lolol.. I obviously hafta lift-off where the sound-hut is, otherwise I'd get meatball flagged all day long. 3-strikes and I'm out |
06-21-2011, 01:19 AM | #27 |
Rep 191
Reviving this thread.. what are your options when you are at Laguna and exceeding the sound limit? I may go to a track day there later this year but I am almost positive that the car will exceed the 90db limit.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
06-21-2011, 04:14 AM | #28 |
///M-fanatic
193
Rep 3,885
The limit there is 92dB. What are your exact mods in terms of sound? From your signature, I'm seeing euro headers and SS race mufflers. With those two, you might already be borderline. IIRC, my car ran 88dB when it was bone stock.
Some options available (for anyone that's interested): 1) drive to the left-most side of the track when passing by the sound hut [between turns 5 and 6] 2) let off throttle a bit when passing the sound check hut 3) upshift a gear temporarily while passing sound hut to bring the revs down 4) try to attach tin foil-type bent tubes in the exhaust tips to direct sound to the driver's side orrr 5) all of the above lol... I wouldn't recommend clutching out of gear just to bring the sound down and pass sound check, since being in-gear is more stable than being out-of-gear. Also, I might recommend that when you do visit Laguna with whichever host you're running with, just ask the track marshall for a sound check. Every car gets three strikes per day; three strikes and you're done for the day. But requesting for a "sound check" will not count as a strike against you. It is merely used as an FYI. When you're on your free sound check run, just gun through right past the sound check hut. You could try one lap running closer to the sound hut (righthand side), then one lap in the middle of the track, then the third lap farthest away from the hut (lefthand side) and compare the dBs. |
06-21-2011, 04:18 AM | #29 |
///M-fanatic
193
Rep 3,885
By the way, my car with:
- JVT headers - SS uncatted section1 - SS x-pipe - SS race mufflers Altogether registered 106dB last time I was @ Laguna. And the main track marshall was NOT happy |
06-21-2011, 10:55 AM | #30 |
Rep 191
- Euro catless headers
- SS uncatted section1 - SS x-pipe - SS race mufflers so... yeah..
06-21-2011, 08:17 PM | #31 |
///M-fanatic
193
Rep 3,885
hahaha okay yeah, then you'll be at around 106dB as well if you don't use any of the above-mentioned options/methods lol
During my final lap of the final session of the last track day I went to, I blew by the sound hut, as close to the hut-side of the track as possible and was almost at redline. And that's how it registered 106dB and the main track marshal came to scold me in the paddock |
