      09-08-2008, 12:05 AM   #23
taku
taku lacorsa
Japan
Drives: Z4MC
If you put thi wheel with std suspension it will be out from your fender.
A negative camber attaches naturally by about one degree when lowering with the suspension abou 20mm.
But wheels are still out from fender.
when the camber is put 2.5degree it's perfect. like my photo.
Rear wheels are no problem.
      09-09-2008, 10:57 PM   #24
taku
taku lacorsa
Japan
Drives: Z4MC
If you put this wheel in stock suspension,your wheels out from fender.
So you must need camber.
      09-22-2008, 10:31 AM   #25
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
181
Drives: Z4M
umm i dunno if you guys havnt seen this yet but it looks like it fits fine. offset is really aggressive in the front though
http://www.m3post.com/forums/showthread.php?t=172092
      09-22-2008, 10:43 AM   #26
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Taku, thank you for the info.
With the negative camber, is there any problem with rubbing?
      07-24-2009, 01:23 AM   #27
spg
spg's Avatar
Drives: IR Z4mC
Revive this thread! Any one else get oem E92 M3 18"s on the Z4MC yet? PICS!?
      07-27-2009, 09:21 PM   #28
b0bab0i
Drives: 03 TiAG z4 3.0i w/ hardtop
http://www.vortextuning.com/Info/html/VT908.html
They make replicas of the E92 M3 wheels.
Here are some pics of the replicas
They make it in E46 M3 fitment which is very similar to Z4M
They also make it in E46 Non-M fitment which are similar to Non-M Z4s
      07-28-2009, 01:42 PM   #29
apexstrafer
Drives: Z4 M Coupe
The reps aren't really the right offset for Ms. Too flat.
I'd love to see how these would look on a black M Coupe, or any other dark color. It's time for new tires and I'm considering picking up a set of these with stock PS2s from the M3 board.
      07-29-2009, 07:28 AM   #30
mike87
Drives: BMW
eh, rim doesn't go too well with the car but the fitment is good
