08-08-2010, 11:11 PM | #1 |
Rep 291
Question on TPMS, switching out tires/rims
I am getting rid of my stock 18" wheels on my 03 Z4 3.0, and will be putting on aftermarket rims and tires.
Do I need to unmount the tires from my stock wheels and pull out a TPMS unit to put into the new rims? |
08-09-2010, 08:27 AM | #5 |
Imola Lover
26
Rep 749
Yes.
08-09-2010, 09:11 AM | #6 |
instagram 997turbotom
279
Rep 7,377
strange. I thought my '03 had them. I mean...it told me when the pressure was low
08-10-2010, 07:39 PM | #7 | |
Rep 76
edit : Im not sure which year this was up too but i believe they changed over to TPM's in 2006 or 07. |
08-10-2010, 07:52 PM | #8 |
M = Midlife Crisis
65
Rep 2,006
TMS/TPMS System pre 2007ish monitors wheel rotation off the ABS sensors - I believe it's +/- 5% on any one wheel triggers low pressure...
2006 Z4MC - #LL93158
08-11-2010, 03:13 PM | #9 |
Rep 1,855
While we're on the topic of TPMS, what would happen if I replaced all of the tpms equipped wheels with non tpms equipped on my07 M coupe? Besides the TPMS light coming on, are there other effects? (eg: abs or tcs not working)
Apology if this has been covered.
08-11-2010, 08:05 PM | #10 |
M = Midlife Crisis
65
Rep 2,006
No - just dash warnings - best to add back the sending units on the new wheels....IMO
08-12-2010, 09:04 AM | #11 |
Rep 623
So, how about another question...
So what do the owners of two sets of wheels do? Same TPMS in all eight or does it have to be programmed to each set of four? If all are stored in the garage, will the car read the air preasure in the four that are not on the car also? Steve Last edited by ShakyDog; 08-12-2010 at 09:05 AM.. Reason: Kan't spell |
08-12-2010, 09:12 AM | #12 |
Rep 1,855
^^ I have another set of 4 wheels with TPMS in the garage close to the car (with tpms wheels). . .No lights thrown. Of course, all 8 of the tires are full of air.
08-12-2010, 09:31 AM | #14 |
Imola Lover
26
Rep 749
Watch the classifieds sections of the various BMW forums. I got a nearly-new set for $100 shipped.
11-16-2010, 06:08 AM | #16 |
Rep 2,138
Drives: Me
From SIB 36 05 05:
The yellow tell-tale must illuminate during the NHTSA required test within 20 minutes when there is a 25% loss in tire pressure (any or all of four tires). |
11-16-2010, 06:31 AM | #17 |
Rep 632
FWIW, I also have two sets of wheels with sensors in all wheels, and I swap them back and forth with no problems what so ever.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
11-16-2010, 08:18 AM | #18 | |
Rep 165
Did you have the TPMS sensors in the 2nd set of tires calibrated by the dealer or did your computer accept the the new tires without calibration?
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
11-16-2010, 05:17 PM | #19 |
Rep 632
I did nothing beyond have them installed when I had my tires mounted up on the new rims. I installed the TMPS sensors on the wheels and then took them to a shop to get tires put on. To be honest, now that I think about it, I didn't even check that the new ones had the same pressures and the original ones and it didn't set anything off. Which ever set is not on the car is sitting right next to it when it is parked (because I don't have any other place for them currently), don't know if that is affecting the situation or not. Basically, when I start the car, or back it in after driving it, the car is next to 8 TMPS sensors at one time, the ones on the car and the wheels sitting right beside the car.....
11-16-2010, 07:33 PM | #20 |
Rep 165
Does anyone know if this effects the 2006? I believe that I once read on this forum that the 2006 Z4M computer will not set off the low pressure light light if sensors are not used. Can anyone ellaborate? Thanks...
11-16-2010, 10:58 PM | #21 |
DHS
205
Rep 4,011
Drives: 2023 M4, 2020 Land Rover
Not an issue really. I have them on my OEM 18s and not on my Volks. Just dash light so I dont worry about it.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
11-17-2010, 04:51 PM | #22 |
M = Midlife Crisis
65
Rep 2,006
We don't have TPMS sensors in the wheels...
