07-25-2020, 09:44 AM | #1 |
Rep 97
Rear springs need changing
The two rear springs on my Z4 need to be changed (cracked) and I am wondering if there other less expensive brands I can buy other than a dealer's OEM?
Thanks |
07-25-2020, 03:53 PM | #2 |
Rep 2,551
I'd go for something like H&R sport springs on all 4 corners.
07-25-2020, 05:09 PM | #3 |
Rep 355
both sides? thats rare. Unless you're a suspension fanatic, I'd but some at a Jyard personally.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
07-26-2020, 12:58 PM | #5 |
your average JAMF
3141
Rep 4,095
The factory springs were inadequately coated (probably just spray painted?). Most of the spring failures you see is in cold weather climates with salty roads. Out west it's almost unheard of.
If you have to replace a pair of springs, what about the shocks? Are they original? If so I'd definitely do all 4 springs & shocks/struts at once, as well as all related bushings/mounts (FCABs and RTABs for sure).
'21 M2 Comp
'19 Golf R |
07-26-2020, 03:23 PM | #6 |
dances with roads
4737
Rep 4,099
I'm in a salty climate and the only spring I ever had fail on me was branded Prodrive (*wave* subiefolk). It had some kind of plasticky coating on the outside, which I imagine once it inevitably cracked, held the brine against the every-flexing steel spring, something which my very slight metallurgical knowledge tells me is a perfect storm for eating through steel.
07-27-2020, 05:41 PM | #8 | |
Rep 4,057
https://www.nace.org/resources/gener...vice-corrosion Last edited by Huz-Z; 07-27-2020 at 05:54 PM.. |
07-27-2020, 06:15 PM | #9 | |
dances with roads
4737
Rep 4,099
07-27-2020, 06:27 PM | #10 | |
Rep 4,057
https://www.nace.org/resources/gener...rosion-fatigue https://www.nace.org/resources/gener...osion-cracking https://www.sciencedirect.com/topics...g/stress-riser Last edited by Huz-Z; 07-27-2020 at 08:14 PM.. |
08-08-2020, 07:37 AM | #11 | |
Rep 244
Drives: 2006 330i Manual
I bought the German brand Suplex from ebay for about 180.00 plus tax for both of my rears. They work fine and raised the rear back up to stock height. They are for NON sports package Z4s. After my research these were the closest to OEM non sports package coils that I could get and the price was right. Last edited by Mantraxalos; 08-13-2020 at 11:56 AM.. |
08-10-2020, 06:10 AM | #12 |
Rep 2,051
I see that brand come up a lot on this forum for these Zed's and Zee's. What is so special about them and what does it do to the car's ride and handling compared to OEM? Must admit I'm always skeptical of aftermarket suspension parts.
08-10-2020, 11:50 AM | #13 | |
Rep 779
I'm interested in the same info, I can't lower the car anymore, bad nyc roads, is there HR that doesn't lower the car? I had H&R in my Acura TSX, I couldn't really tell if there were any difference
-Roranji
08-10-2020, 10:41 PM | #14 | |
Rep 2,551
Not sure what model H&R springs you used on your Acura, some are close to stock. I believe the only H&R springs for the Z4 are sport springs (since it's a um, sport car) with mild lowering. Since you say your roads are bad, better stay with stock springs and not have better handling. |
08-12-2020, 11:53 AM | #16 | |
Rep 779
I haven't driven the car in almost 2 months.. They're building new overpass and replacing bridges on I95.. roads have been cut up for repaving for months and still not done. It be waste of money putting it in and letting it sit till 2021.. I mean I can drive the car to go get milk but I don't need springs for that.. spring 2021 is when I can drive it https://www.thruway.ny.gov/oursystem...staging-v7.pdf
-Roranji
08-13-2020, 11:40 AM | #17 |
Rep 779
Well, might as well prepare for future when roads are fix.. I forgot where I read it, better off getting coil over if you change to non factory springs ? I'm looking at KW v1s now. lol I saw bc racing coils comes with shorter end links, I assume I will need it for KW ?
-Roranji
08-13-2020, 01:08 PM | #18 |
Rep 244
Both of mine were cracked at about 150k mi last summer. I noticed them both when I tried to change the diff fluid and the drain bolt could no longer be easily accessed since the ride height changed. They must have snapped while sitting over winter.
