      07-18-2018, 12:05 AM   #1
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
I've met a guy that built a J test pipe to a Z4M with RPi. He said it reduces the idling decibel from almost 100 to 88dB. The volume of the sound and tone stays the same but drone is minimized next to none.
Since he loved the RPi sound the best, out of all the other exhaust for the Z4M but can't bear with the drone, this is his solution with good results.
thoughts?
      07-18-2018, 06:31 AM   #2
RABAUKE
Drives: Porsche 993, 2014 MB GLK
I guess you'd really have to hear it to judge if it cured the problem of drone and sounded better quieter at idle. Can you post a video?
      07-18-2018, 08:17 AM   #3
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Isn't the first time I've heard of this, and I have heard that it works very well. Called a Helmholtz chamber. Here's more pictures:
https://www.facebook.com/pg/flowauto...60298500704472
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      07-18-2018, 08:49 AM   #4
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Exhaust systems that are professionally engineered typically take into account for equal length headers (or not), length of piping to the mufflers, CATS, resonators, exhaust gas pulses, etc.
Curious how this app affects overall exhaust performance.
Racerbruce
      07-23-2018, 11:47 AM   #5
///Mcoupe
Drives: 2007 M Coupe
So is the added piece just a resonator thats been capped ?
      07-24-2018, 02:06 PM   #6
RossBMWZseries
Am I the only one not really bothered by the drone the RPI's make? I drive it like a grandma, sometimes like a grandma on an energy drink (not any more aggressive because rod bearings), and i just happen to always enjoy the sound at any given RPM, it's glorious!
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      07-24-2018, 03:11 PM   #7
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Yes but the length of the pipe is the key as well as the capped resonator. They were able to weld it to hide the resonator behind the smaller tip so they are not as visible once installed. They try various length based on calculation and this works the best.
I will be able to hear this car next month and I'll report back.
Ross, Ear wax checked? I'll be recording trunk mounted video soon to compare with all other exhausts I've had to our Youtube Channel. It is very boomy at the wrong rpm.
      08-04-2018, 02:27 PM   #8
TurboDream17
///M Enthusiast
TurboDream17's Avatar
Drives: '07 Z4M Coupe
Since the end of the pipe is capped, the exhaust performance will be exactly the same. It's like having an electric circuit with an open going to nowhere -- all of the current/exhaust gas will flow out the only way it can.
///M Coupe - Volk TE37's 19x10.5R +22 19x8.5F +30 | KW V3 w/ Clubsport rear springs | RPi exhaust | Autosolutions SSK | RE transmission mounts | RE RSM's | Vibra-Technics engine mounts | RPi scoop | RPi skid plates | Tekarbon spoiler | Apex wheel studs | Blox burnt titanium lug nuts | UUC Front 27mm Swaybarbarian | Status Gruppe adjustable front links | EAS Blacked out kidneys | Full Beisan Vanos Refresh
      12-18-2020, 11:00 PM   #9
TurboDream17
///M Enthusiast
Did you ever have a chance to hear how the car sounded with the j pipes?
      12-19-2020, 12:59 AM   #10
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Yes, it sounded the same as the original Rpi and cut out 90% the drone..
It's still lound and raw but boominess while cruising is almost gone..
I'd go this route if I didn't score my current setup..
      12-20-2020, 08:35 AM   #11
CJW2OO4
CJW2OO4's Avatar
Wonder how much something like this would cost / if someone would do that locally
