08-29-2013, 12:34 PM | #1 |
Rep 12,565
Uneven Tire Wear ONLY on Left Side?
I run RS-3 255/40-17 square on 17x9. I run -2.8* up front and -2.0* in the rear (I would run more camber up front if possible but the shock towers are already in contact with the nut under the coilover adjuster). Car weighs approx 3200lbs without driver.
Tires have seen approximatey 10-12 track days, most of which were LRP and NJMP (both Light and T-bolt) and I typically run 38psi hot. What I'm trying to figure out is why I have this pattern of uneven tire wear ONLY on the left side of the car. Front right and rear right have slight uneven wear on the inside but it's nothing bad like this: Front left Rear left |
08-29-2013, 01:10 PM | #2 |
1821
Rep 5,337
The blue hue indicates the tire(s) have been near or over their maximum operating temperature. It is not unheard of if some of the tracks you visit have long sweepers in one direction only. For example, since we haven't visited Willow Springs International Raceway in over 2 years, my front right is starting to wear more than the left due to the long, massive banked oval portion of California Speedway (and the 1 day we visit Buttonwillow isn't going to counter that effect).
Since the tires appear directional, I would just mount them inside out and swap left and right every 2-5 events to maintain even wear, especially if the wear is caused by long high speed sweepers in one direction only.
08-29-2013, 01:28 PM | #3 | |
Rep 12,565
08-29-2013, 01:39 PM | #4 |
1821
Rep 5,337
right handed sweeper = all weight put on the left wheel/tire. Looks to be about right?
EDIT: Okay, whoever designed that track has a VERY sick sense of humor. Not unlike the dude who designed Auto Club Speedway.
08-29-2013, 01:52 PM | #5 |
Rep 12,565
LOL... Btw I take it adding camber won't alleviate this?
08-29-2013, 03:07 PM | #6 |
703
Rep 7,850
08-29-2013, 07:10 PM | #7 |
enthusiast
48
Rep 1,695
Rotate your daily at the track in a way that moves the most wear to the least wear. That being said, you obviously need more camber on the rear for the track you are driving, and your spring rates. Based on the wear, there is more traction to be gained than you are using.
And it changes as your skills improve. One year, with the same tire, x camber may work, but a year later you are driving faster and will need more camber, stiffer springs, or sway bars to compensate. This is the fun part of high performance driving: setting up the car for fast. |
08-29-2013, 07:15 PM | #8 | |
Rep 12,565
08-29-2013, 08:10 PM | #9 | ||
Rep 4,531
Find a SCCA or NASA person who does tires, and get discounts and dismount and flip the tires to the other wheels. With the right connections I can do my tires or $10 a tire. $40 to mount, flip, remount and balance. |
08-29-2013, 09:18 PM | #10 | |
enthusiast
48
Rep 1,695
If you do that and fix your camber issue, your tires will wear evenly. Last edited by seank; 08-29-2013 at 09:26 PM.. |
