      04-17-2012, 03:05 AM   #1
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Hood Rattling?
I've recent discovered that my hood will rattle above certain RPM.
Initially, I couldn't find where did the rattle sound came from. I check all the usual suspects. Fire wall brace, engine mount etc but to no avail.
Last week when I was washing the car, I felt the hood area on my driver side has 1/4" play. It is securely latched on but I can push down that part of the hood and viola; the rattle sound is exactly that I've been hearing for months. It's about 1 feet below the vin plate on the windshield in the direction towards the headlight.
I tried the right side of the hood, but it has no play and no sound.
Is there any kind of adjustment that I can play with? It seems to me that part of the hood is not being push back up properly or something is loose and needs to be tighten up.
TIA.
      04-17-2012, 08:04 AM   #2
chickdr
Drives: 2006 M Roadster
Check the bump stops inside the engine bay. One of yours could have failed:
http://www.bimmerfest.com/forums/sho...4&postcount=59
      04-17-2012, 09:36 AM   #3
Pheonix
2007 BMW/Z4MC  [0.00]
I have the same issue so what I did was putting some rubber hose on the latches. They definitely pulled the hood down tighter but the problem didnt go away (stil hear somekind of rattling)
      04-17-2012, 11:07 AM   #4
kcdedric
kcdedric's Avatar
Drives: E90 M3
Funny, I had this same exact problem and also figured it out while washing the car.
I can't remember exactly what the dealer replaced/adjusted, but it was either the driver's side lock (leaning towards this) or the bump stop. Problem fixed.
Le Mans Blue '09 BMW M3 Sedan - Current
Polar Silver '04 Porsche GT3 - Gone
Persian Blue '08 Lotus Exige S240 - Gone
Space Gray/Imola '08 BMW M Coupe - Gone
      04-17-2012, 11:24 AM   #5
scottyD
scottyD's Avatar
Drives: 07 3.0si Coupe
In addition to backing out the threaded bump stops, you can also remove the black plastic cover around the base of the metal latches on the hood, and then since the latches are threaded into the hood you can turn them 180° one way or the other to adjust their position, and then re-attach the black plastic locking piece.
This allows you to have the hood aligned flush with the quarter panels and bumper, but also tight and not smacking around.
It will take some fiddling with to get it just right.
      04-17-2012, 08:06 PM   #6
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
I'll check both of them. Thanks a bunch guys!
      04-18-2012, 11:22 AM   #7
BAK613
Drives: Z4 M Roadster (E85)
I've had a different hood rattle problem. When parked on an uneven surface I noticed that the front corner of the hood (driver's side) was up slightly 1/4". Turned out that side was not latched, no amount of pushing would get it to latch.
Here's my work around, maybe you have a better approach? Basically I cycle the problem latch: after unlatching, take a screwdriver and manually push the hook to the latched position and then pull the hood release. After that I can just drop the hood from abou 12" it it will latch on both sides.
Any ideas on how to fix this?
Thanks,
Bruce
      04-18-2012, 03:44 PM   #8
chickdr
Thanks,
Bruce
I assume you have tried lubrication? It may just be a defective latch.
      04-18-2012, 04:59 PM   #9
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
I have Version #2 on the link that you posted. I open the hood last night.. the passenger side ejector didn't pop up like the driver side.
So I use a screw driver and try to turn 90 degrees to let it pop up. However, once I put a little force on it... the pin/ejector went all the way in and fell straight through onto the belly tray.
So was it broken? or I can pick it back up and re-use it?
I have to decide whether I need to jack the car up and look for that pin if it's re-usable.
TIA,
      04-18-2012, 06:55 PM   #10
scottyD
scottyD's Avatar
You may want to try to adjust the vertical position of the latch in the hood using the method I explained earlier. Maybe the latch is not far enough down for the latch to engage?
I had these break once already, bought new ones, and they also broke. So, I decided I'm not buying any more of these from BMW since there's obviously something wrong with them. I took all of the spring-loaded guts out of the bump stop and backed them out about 3 or 4 turns so they stand higher, but they don't have the spring loaded ejector.
It seems to work pretty well for me so far. There's still the opportunity and the need for adjustment of the rubber bump stop and the metal latch to get things just right (flush when latched and not rattling).
      04-18-2012, 07:22 PM   #11
chickdr
TIA,
This is hilarious. After posting my answer to you and as I was drying my car today, I noticed the driver side ejector wasn't popping up on mine. I did EXACTLY what you did and mine fell into an inaccessible area underneath. I took the plastic shroud off the center area to see if I could get to the piece which was not effective. Then when I was replacing the shroud, I lost one of the expandable screw/rivets which holds it in place! Now I am ordering two new parts for my car....
      04-19-2012, 11:54 AM   #12
jragan
Imola Lover
jragan's Avatar
The "Buffer Stop with Ejectors" are a well known problem and they come in two different spring strengths. Our cars come with the very high-strength spring that a lot of folks have replaced with the lower-strength spring units so they don't put so much pressure on the bottom of the ejector and break through. Also, make sure you don't slam your hood as that contributes to the ejector pushing through the buffer stop.
Hers: 997-1 C4S: Pics
      04-20-2012, 03:20 AM   #13
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
P/N: 512248137994 Low-Strength
or
P/N: 512438187291 High-Strength
I ordered 4 low strength one. Two for the hood and will install two for the trunk to get more lift when opened.
They should arrive tomorrow.
      01-14-2013, 06:56 PM   #14
beta
I didn't have any rattling, but my left side hood buffer stop with ejector was broken, thanks for the part numbers.
Here's a picture of the broken and new ones. The top one is the broken one, the cap on the bottom of it fell off so it doesn't have a spring anymore. The bottom cap of the new one is metal, don't know if the old one was also metal since it's missing.
      11-04-2013, 09:38 PM   #15
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
Having trouble finding the lower strength ones online, can someone send me the link?
I can only find the higher strength. And what are the advantages/drawbacks between the two?
      11-07-2013, 10:41 PM   #16
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Check out part number 7. Both of mine are missing. This also stops the rattle of the hood.
http://www.ecstuning.com/Search/Site...16856/ES91696/
      11-08-2013, 03:00 PM   #17
bvnguyenp
Drives: Z4M Coupe
Anyone have similar problems with the rear hatch rattling around?
      12-04-2013, 04:20 PM   #18
AmmarYasirA
Ammar
Drives: a lot
Nah mate, but you can check your stops. They should be on the edge of your trunk. Underneath them of course.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      12-06-2013, 12:47 PM   #19
ferrarif1
Drives: F85, G05, E46M3
You made my day! I found one of those on the aluminum undertray when I was flushing coolant and had no idea where it came from. Can someone take a picture of these installed so I can make sure they get back to the right place?
      12-06-2013, 12:59 PM   #20
ferrarif1
Should have done a google image search before asking...picture here if anyone else needs it:
http://www.zpost.com/forums/showpost...09&postcount=7
      12-06-2013, 03:45 PM   #21
antennahead
You're very welcome. I ordered replacements from ECS and the play/rattle in my hood is now gone as well!
      12-07-2013, 10:19 AM   #22
SD ///M4
///Multiple
SD ///M4's Avatar
Just above this post is my post showing that they should line up with a sticker mounted on the inside edge of the fender: http://www.zpost.com/forums/showpost...61&postcount=6
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
