      03-31-2017, 11:24 AM   #1
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
Part Help
Hey guys. Ive been searching for this part for what seems like hours now. Ive narrowed down the part diagram... But now Im confused as to which nut I need. Ive attached the part diagram, and two pictures of what Im looking at on my car.
For some reason, the drivers side only has the bolt but not the nut?? No idea what happened but I can't seem to figure out which nut it is from the diagram.
The nut goes over the side panel and the bolt goes behind a bracket that also supports the side mount for the headlight. Hopefully the pictures help.
Thanks!
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      03-31-2017, 11:27 AM   #2
AmmarYasirA
Ammar
Drives: a lot
Oh, also, the bumper bracket is also broken, so that might make the picture look confusing if someone has taken the bumper apart before.
The bumper has dragged along the pavement so much its broken like 3 brackets
      03-31-2017, 09:45 PM   #3
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
Would you be able to take a picture of it from another angle?
My first instinct was to look at the headlight assembly but this diagram doesn't show anything above parts 1 and 2.
2008 Z4 3.0si Coupe
      04-01-2017, 04:47 PM   #4
AmmarYasirA
Ammar
Drives: a lot
Yeah, I cant seem to find that piece anywheeeerrreee on realoem. However, from looking at the diagrams, its seems more and more likely that the diagram I posted would have the bolt I needed.
I may also be completely wrong. :
      04-04-2017, 06:28 PM   #5
AmmarYasirA
Ammar
Drives: a lot
Update:
So it seems like that part had actually nothing to with the fender. Was looking at Shipkiller 's post and it seems to be that this would be the correct diagram.... however... theres a bolt in the diagram... but no nut...
