      03-13-2017, 07:03 AM   #1
imported_mega
No_Country
122
Drives: various bmw's
2006+ passenger seat sensor disable ncexpert
Just attempted to disable my passenger seat sensor, car has an ACSM module I set OC3 to nicht_aktiv and unhooked the 3wire sensor. Cleared errors and I'm left with just these two issues.
ista/d shows the seat sensor module in red now, and the airbag module reports 1 fault 93D7 Internal Control Unit Fault. When I did this on my mini's it stopped checking the seat module. and returned no errors.
anyone have any ideas?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      03-13-2017, 10:22 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Pretty sure you can't just code it out. There is a pax seat sensor simulator that ... Apperently.. acts like the sensor still works, resulting in no red light on the dash.. does it actually work?? Nfi.. I haven't got around to install it..
Powered by
      03-13-2017, 04:17 PM   #3
imported_mega
No_Country
122
You can on all other BMW not sure why z4 would be different
      03-13-2017, 06:23 PM   #4
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
You can code it out. I'm no expert on that software, so I hired "CodeMyCar" to do it for me. Very reasonable pricing and they can do it remotely via your laptop. The owner, Okee, was very easy to work with and coded out my broken passenger occupancy sensor and cleared all the fault codes. Now I have no warning lights, and best of all my airbags are back working again. If by some chance I need to turn off the passenger airbag, I'll use the key switch on the passenger side of the dash. Best money I ever spent and sure beats the dealer cost to replace that damn sensor, which would most likely break again in a few years!
John
      03-13-2017, 08:16 PM   #5
imported_mega
No_Country
122
I've done it before but not on a z4 this module is a little different, I just verified it's all coded off but I still have 93D7
      03-13-2017, 08:42 PM   #6
antennahead
I'm doing this from memory, sitting in the front seat as he was working, so this may or may not help. The coding was done with the occupancy sensor plugged in. Then he had me turn the car off and unplug the sensor. Then we cranked the car back up and he went in and cleared the codes. I "think" that was the procedure, again, trying to recall it from memory a while back. Hope you get it worked out.
      03-13-2017, 09:34 PM   #7
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
sub'd for info
      03-13-2017, 10:01 PM   #8
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Wow, cool.. do you remember how much you payed?? I Wonder if the same can be done for the pre tensioners?
Thanks for steering me straight guys
Powered by
      03-13-2017, 11:49 PM   #9
antennahead
http://www.codemycar.com/
Pretty much answers all your questions.
      03-14-2017, 05:11 AM   #10
imported_mega
No_Country
122
Pre tensioners are important but yeah I see an option to turn them off in NCS expert/ncsdummy
      03-19-2017, 04:23 PM   #11
imported_mega
No_Country
122
still no luck with the 93D7 error, it refuses to clear.
      03-31-2017, 08:08 AM   #12
3GFX
3GFX's Avatar
Do you have the SSS program?
