View Poll Results: Headers; jethot or not | |||
Hell yes it's easilly worth the extra $300 | 11 | 73.33% | |
No, save your money | 4 | 26.67% | |
Voters: 15. You may not vote on this poll |
08-23-2012, 01:52 PM | #1 |
Rep 11,667
JetHot coating on headers; worth it or not?
I know '-villa's opinion on this
&.... it has been discussed a few times already. Assuming cost is in the $300 range Just looking for opinions is it worth it or not. what are the realistic benefits of jethot coating headers? (new installation)
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 08-23-2012 at 02:52 PM.. |
08-23-2012, 01:58 PM | #2 |
Rep 5,328
i would do this if i was putting in euro or aftermarket headers, if their already in place..... i wouldn't bother imo!!
hell id do it just for the clean look, let alone the benefits of heat retention..... looking at your cars spec, i think its time you added FI !!!
08-23-2012, 02:14 PM | #3 |
Rep 11,667
^ Yes, new installation it is.
FI? sounds like balls out fun, but too many legal issues here for me. so, looking at the normal NA mods; gain a little power where you can & try to drop some weight
08-23-2012, 02:19 PM | #4 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
When I had my AA headers they got hot enough to boil the windshield fluid out of the cleaning jets on to my nice clean hood. Very frustrating. I would do it and will do it on my euro headers.
08-23-2012, 02:25 PM | #5 | |
Rep 5,328
WOW!!! interestingly ive never had such an issue with my stock euro headers... thats the thing with aftermarket manifolds.... bmw spend millions and millions on working out where heat is leaving the manifold right down to the shape.... i know for a fact... the aftermarket just simply CANT apply this level of detail.... as well as being free flowing the headers have to disperse heat and a certain way and equal way at that.....
08-23-2012, 04:11 PM | #6 | |
Dark Sider
129
Rep 1,779
08-23-2012, 04:50 PM | #7 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
08-23-2012, 08:10 PM | #9 |
703
08-23-2012, 08:27 PM | #10 |
Rep 11,667
^good points.
08-23-2012, 09:27 PM | #11 |
///M-fanatic
193
Rep 3,885
I used black VHT header paint on my JVTs before I installed them, and it only cost me like $10 for the spray can. Turned out very clean, as my friend helped me spray them, and he's done lots of paint work before
08-23-2012, 09:38 PM | #12 |
instagram 997turbotom
279
Rep 7,377
I had mine coated with the upper level one, in grey color. Why? Because underhood temps are significantly reduced, and I can almost touch them when they're "hot". Very little heat radiates from them. Great for FI application
08-24-2012, 10:56 AM | #13 |
Certified Adrenaline Junkie
43
Rep 1,325
Jet hotted my headers.
2nd thing I have jet hotted. First thing was my turbo manifold for 91 Miata. I used to run with a group of turbo'd miatas and there was a significant difference in under hood temps for the manifolds that were jet hotted vs those that were not using the same turbo kit. |
08-24-2012, 11:16 AM | #14 |
Rep 11,667
^ FI, I can definitely understand.
It just seems like a little overkill on a NA motor. You would think that eliminating the header CATs would let things run cooler than OE. I was surprised that mousitch had the problem with his AA's ....seems strange.
08-24-2012, 11:29 AM | #15 |
Rep 398
I did it, and left the heat shield off.
It makes a difference. Noticed (not measured), that car warms up a bit quicker as well.
BSM Z4M Coupe
08-24-2012, 11:40 AM | #17 |
Rep 11,667
08-24-2012, 12:14 PM | #19 | |
Dark Sider
129
Rep 1,779
08-24-2012, 12:36 PM | #20 |
Rep 11,667
Were you able to reinstall the heat shield with the AA headers?
08-24-2012, 01:46 PM | #21 |
Dark Sider
129
Rep 1,779
Yes. Not an issue at all. in fact the only issue I had was one or two of the studs backed out woith the bolt. Easy install. Took my time at 10 hours. The O2 sensors were kind of a bitch. Used a Harbor freight removal socket. I will search out a better tool next time. Easy to twist the wires and damage.
08-24-2012, 02:51 PM | #22 |
Rep 195
FYI, coating the headers helps retain heat, which helps with exhaust gas velocity and adds a few horsepower. It also lowers underhood temps as others have mentioned.
Additionally, it helps the cats get up to operating temperature sooner, so it helps with emissions. |
