05-27-2011, 02:04 PM | #1 |
Rep 59
Z4 Maintenance Information
I'm trying to put together a table of information related to maintenance on the Z4's. For the DIYers. But I'm pulling a few blanks and would appreciate any input. The information I have so far is either from the manuals/inspection sheets/TIS or various posts on this and the other forums.
2006-08 Z4 M Roadster / Coupe Engine Oil Volume : 5.5 litres Suggest Interval : Recommended : Castrol TWS Motorsport SAE 10w-60 Synthetic Castrol Formula RS 10w-50 Synthetic Parts : Engine Oil Filter BMW PN # 11 42 7 833 769 Engine Oil Filter O-ring PN # 11 42 1 741 000 Oil Pan Plug PN # 07 11 9 904 550 Oil Pan Plug Washer PN # 07 11 9 963 151 Transmission Oil Volume : 1.5 litres Suggested Interval : Recommended : Catrol MTF-LT-2 PN # 83 22 0 309 031 Options : Amsoil 5w30 Manual Syncromesh Amsoil 75w90 MTF 1/2 Redline D4ATF & 1/2 Redline 75w140NS Gear Lube. Royal Purple Pentosin MTF2 Parts : Screw Plug with Gasket Ring PN # 23 11 7 531 356 Differential Oil Volume : 1.1litres Suggested Interval : Recommended : Castrol SAF-XJ PN # 83 22 1 467 993 Castrol SAF-XJ + FM PN # 83 22 2 282 583 Options : Amsoil Severe Gear 75W140 Redline 75W140 GL-5 Gear Oil Parts : Notes : Find a parking lot and do several tight circles in both directions to aid lubing. Brake Fluid Volume : 1 litre Suggested Interval : Power Steering Fluid Volume : Suggested Interval : Coolant Volume : 10.7 litres Suggest Interval : Instructions for Oil/Inspection Reset
Next oil service interval will be shown and disappear Oil service lamp is now reset Last edited by biped; 05-29-2011 at 12:50 AM.. Reason: Added volume information from Ron Stygar |
05-27-2011, 02:09 PM | #2 |
Rep 5,329
great post :-)
05-27-2011, 08:04 PM | #5 |
Rep 753
My intervals
Engine Oil - Every 2-3 track days or 3K-4K miles (Blackstone every sample) Trans Fluid - every 40K miles Rear Diff Fluid - every 20K miles Coolant - Every 50-55K miles |
05-27-2011, 09:31 PM | #6 |
Bad Lieutenant
233
Rep 3,517
Is everyone forgetting power steering fluid? I've been using a turkey baster and Mobil 1 synthetic ATF at 30k intervals.
05-28-2011, 12:07 AM | #7 |
Rep 1,663
Engine Oil suggested interval I'd say 7.5k. It lines up really well with the regular schedule, it's twice as often as BMW recommends, and most oil analysis I've seen showed that it would be fine. I'll see if I can dig up some links.
05-28-2011, 12:17 AM | #8 |
Rep 59
Heh, this is cool, I was naive and didn't factor the track guys will be exchanging fluids more regularly, ideally I was just looking for factory recommended intervals. I guess just expected track guys to already be on top of their own needs But having that info is great.
05-28-2011, 01:27 AM | #9 | |
Rep 820
Drives: 2007 Z4MR silver grey
05-28-2011, 11:55 AM | #11 | |
Rep 494
Great post, i say sticky!
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
05-28-2011, 12:03 PM | #12 |
More of this than that!
29
Rep 817
Once this is complete...this should be a sticky for everyone to have quick access to it.
Now if someone would post the same for the Z4 2.5, 3.0i and 3.0si
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
05-28-2011, 12:07 PM | #13 |
Rep 421
05-29-2011, 12:38 AM | #15 |
Rep 483
This is great. Let's make this a sticky then hang the first person to ask "What fluids and how much?" Just like I want to scratch my eyes out when a newbie asks if the Z4 is a good car to buy.
If I'm going to rant I'll contribute. Here's what I've compiled for my 3.0si N52 engine. Same for the 3.0 if it's an N52 (2006 and later I think). Not sure about the 2.5. ---------------------------- OEM Spark plug = 12120032138 Bosch Spark Plug FR7NPP332 (cheaper to buy Bosch plugs then BMW OEM part number for exact same plug) Oil: OEM Oil 07510017866 = 6.9 quarts (safe to use 7.0) Oil options = Mobil1 0w-40 Full Synthetic Euro Spec OEM Oil filter = 11427541827 (comes with drain plug crush washer and two filter housing o-rings making it cheaper than buying filter, washer and orings separately) BMW Coolant 82141467704 = 9.3 quarts Link to DIY here. Need about 5 gallons fresh water and 1.5 gallons of BMW coolant (Mixes with water 50/50) 64316915764 Charcoal Cabin Filter 13717542545 Engine Air Filter 61610154440 Wiper Blade Refill (cut to size) Edit: I'm adding this info on ATF. I know there's a huge debate on "lifetime" fluids and such, but this is what I did. ZF Automatic Transmission OEM ATF Fluid = ? ATF Fluid Options = Valvolene MaxLife Dex/Merc ATF = Drain and refill ~8 quarts OEM ATF filter and plastic pan = 24117536387 Interval = BMW says 100k then drain and replace filter. I drained and refilled at 25k and plan on draining/refilling WITH filter change at 50k. Might I suggest links to BavAuto and Tisher? You have to compare prices between the two. BavAuto wins if you meet their $150 free shipping minimum. Last edited by santov; 05-29-2011 at 01:03 AM.. Reason: Added ATF info |
05-29-2011, 12:45 AM | #16 |
Rep 59
Not sure if I should amend the non M models to the original post, or start a thread per each. Also wasn't sure about the policy with link posting, I know on the 'other' bmw forum, they have sponsors, and it could be a source of conflict.
I think probably best to rename this topic, not M specific, and will amend your info to it |
05-29-2011, 01:30 AM | #17 |
Rep 483
Oh on Brake Fluid I heard a great idea:
Alternate between ATE Super Blue and Super Gold so when you start to see the "new" color you'll know you've purged the old stuff. I haven't done that since I'm still in warranty and don't want to introduce any warranty issues with aftermarket fluids. But plan on switching to this method post-warranty. In the meantime I just use Valvolene DOT 4 full synthetic. It's very clear in color so still easy to identify when old fluid is purged. |
05-29-2011, 11:09 PM | #19 |
Rep 483
My bad... I had ATF on the brain. The DOT4 I got at Kragens was Prestone. I like it since it looks clear like water making it ready to see when the fresh fluid is pumped out.
05-31-2011, 09:37 AM | #20 |
Long Live the 1911
47
Rep 643
Drives: Hooptie
Stock wheel lugs should be torqued to 88.5 ft-lbs.
01-17-2014, 01:34 PM | #21 |
Rep 185
Amsoil 75w90 MTF these will work in our transmissions? Amsoil is the best out there hands down but I wasn't aware they made anything for our cars. Has anybody ever tried either of them? |
04-26-2016, 11:42 PM | #22 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Bumping this thread up because:
1) I found it very useful 2) Wondering if any additional parts are needed for the differential oil change other than the fluid (washers, etc.). Getting ready to perform diff and tranny fluid changes as I'm almost at 30K miles. Thanks!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
