      03-13-2011, 07:49 PM   #45
-c-
-c-'s Avatar
Drives: bmw
Originally Posted by Incompatible View Post
-c-, another question for you. As an alternative, do you think it would be possible to mount a conventional battery sideways in the box (more towards the center-similar to picture), narrow the battery box, and go with a muffler which was smaller then the oe design? Maybe a 6-7" dia cylindrical without moving the charcoal cannister? Would it be possible to relocate the cannister to the center and leave the battery box in the floor if you were creative with the hose routing?
regurdless of what is done the canister has to be moved as its right in the way of things the battery may work sideways but its going to be tight. its possable to splice the tubing for the fuel canister and mount it wherever, as i had to do that with my scavange line as the "M" and "I" have different engines i had to use only the rear part of the line, so i cut both peices and then re-attatched the line so anything is possable in that reguard.
if you want dual exhaust your going to have to move that emission canister to the center of the car and then re-rout the lines where you can, if its tru as was stated ealier and the canister can be removed and just cap the lines with no ill effects then id go that route as it saves major headache.
      03-13-2011, 10:29 PM   #46
Incompatible
Drives: 07 AW Z4C 3.0Si
Thanks
      03-20-2011, 04:13 PM   #47
-c-
-c-'s Avatar
Drives: bmw
images up of the car finnaly outside of the garage!!!
will be posting images soon of sound clips of M-exhaust on non M car ....... tee hee!~
      03-24-2011, 01:29 PM   #48
-c-
-c-'s Avatar
Drives: bmw
Done Done and Done!!!!
car now 100% operational and drives wonderfully, i cant even start to explain how happy i am. the sound is perfect no drone no ill effects just perfect quiet untill i dont want it to be, also noticed it lacks the metalic sound of the S54 M engine, the sound is more lower pitch!
all around A+ upgrade~~
i will now be taking sound clips and video, how do you post a video on the forum?
thanks guys~
      03-24-2011, 02:07 PM   #49
3002 tii
3002 tii's Avatar
2282
thanks guys~
best bet is to probably use a site like photobucket...
Follow for latest mods
      04-12-2011, 03:13 AM   #50
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
Can't wait to hear the sound clips and for you to get it tuned with the 3 stage.. I think we will all be pleasantly surprised at your numbers!!!!!!!
      04-12-2011, 12:11 PM   #51
MIKe86
Drives: 90 332is
Good job. Looks nice and clean!
      04-12-2011, 01:09 PM   #52
-c-
-c-'s Avatar
Drives: bmw
thanks guys!
sorry i havent posted anything as of yet, still waiting on my bumper from the body shop as its had to be painted 3 times already as they keep goofing it up, and their the best in town! sheees!
anywho i will post all the goods when i get it finally taken care of and all things done, last stuff to do is get the brake convertion done and the 19" wheels and i should be almost their.
      04-12-2011, 01:17 PM   #53
pantydropper
Drives: Scion
nicely done
      04-12-2011, 01:22 PM   #54
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
you can also upload to youtube very easily
      04-12-2018, 10:38 AM   #55
bemel2
Drives: 2006 Z4M
Smile Charcoal canister relocate
ok its all done just need to paint the rear bumper now.
if anybody wishes to see more pics please let me know i have hundreds lol.
i can email them if needbe.
thanks to everyone for your help in making this possable without your valuable pictures this would have been wayyyyy harder than it was.
a VERY big speacial thanks to crfine88 and nofear for all their help in sending in their detailed pics of under their cars so i could make this happen!!!!!!
thanks again guys!!!
Hi. I'm doing the dual exhaust & have already relocated my battery to the trunk but I still need to relocate the canister towards the middle of the rear portion of the car behind the differential. What did you do to yours? Did you relocate it also behind the diff? If so, I would appreciate if you could share the parts that I need like hoses, etc. & it's sources. Pictures would also help. PM me at melnavato42@gmail.com Thanks.
      04-12-2018, 04:03 PM   #56
-c-
-c-'s Avatar
Drives: bmw
You need all the M hoses and you need to locate it to the M location in the middle of the trunk. Theirs a frame piece in the way so just need to run it where the hoses tell you. Just look at any M and you'll get the idea. I'll try and find some pics. It's been almost 9'years lol.
Just realized all the pics don't work any more. I'll have to redo everything
      04-16-2018, 03:16 PM   #57
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
a VERY big speacial thanks to [SIZE="4"]crfine88[/SIZE] and [SIZE="4"]nofear[/SIZE] for all their help in sending in their detailed pics of under their cars so i could make this happen!!!!!!
Glad to see you're still around! Much respect for paving the way!
      04-16-2018, 11:22 PM   #58
-c-
-c-'s Avatar
Drives: bmw
Always ! I ain't going nowhere
Just need to find time to data mine all the old pics and repost.
I'll do it as soon as I have some time.
      04-25-2018, 02:12 PM   #59
Asianoak
Asianoak's Avatar
Drives: '11 E92 M3 & "11 X3
2011 M3  [0.00]
So after seeing some of the dual exhaust setups available as bolt on, and working with my local exhaust shop, I tried something a little different. I didn't relocate anything and instead got some heat shielding from the junk yard and formed it to fit into the channel where the second exhaust is routed. I've had it in place for a year with zero problems. Even after long drives in 90 degree heat I haven't had any issues.
PS pics are prior to heat shielding installation
Instagram: @dasianoak
