      04-20-2013, 08:04 PM   #1
strokeoluck
Drives: 2007 BMW Z4 M roadster
Two misc. questions
1) What's your normal engine operating temp when you're just cruising around town?
2) Do all of the Z's produce an alert sound and flash "37" degrees when it hits...37 degrees outside temp?
      04-20-2013, 08:50 PM   #2
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
Slightly less than in the middle. Whatever temp that is. Slightly over middle after a 25 min track session.
And yup, I believe so. My e46m3 did the same chime at 37 degrees.
'07 MCoupe
lots of mods
      04-20-2013, 09:06 PM   #3
SgtGigglebox
SgtGigglebox's Avatar
Drives: '13 Atacama 35is
Every BMW that I've ever had, going back to 2003 have had the sound and cluster warning at 37 degrees. (Z4s & 3 series)
      04-20-2013, 09:09 PM   #4
strokeoluck
What's the purpose of this warning?
      04-20-2013, 09:16 PM   #5
SgtGigglebox
Im guessing that its just a simple note that the road conditions are becoming questionable, so we lighten up on the peddal
      04-20-2013, 09:22 PM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
1) slightly below middle with my aftermarket oil cooler + supercharger
2) yes
      04-20-2013, 09:24 PM   #7
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Warning of possible icy conditions. Bridges, shadows, etc. can have ice since those areas are colder than the ambient temp.
      04-20-2013, 09:41 PM   #8
brock5ga
Drives: 03 Z4 3.0i
Not sure at what temp it does it, but while my Silverado will not produce an alert, it will flash "ICE" in the temp display when first started at a temp that I know is above 32 deg. also.
      04-20-2013, 10:05 PM   #9
WestCDA
Drives: 2006 Z4R 3.0si
Owner's manual - 'Outside Temperature Warning'.
      04-20-2013, 10:25 PM   #10
GammaZeta
Drives: 1
In Germany, water freezes at 37 degrees.
      04-20-2013, 10:33 PM   #11
Finnegan
Finnegan's Avatar
      04-20-2013, 11:14 PM   #12
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
37 degrees Fahrenheit is the optimum temperature for a race
      04-20-2013, 11:29 PM   #13
boodie1821
Drives: 2007 Z4M Vert
im pretty sure i was able to turn that warning off in my E34...
