02-21-2008, 02:40 PM | #1 |
Rep 79
Help me! Information wheels Z4 M
I have a problem, BBS CH
http://www.tirerack.com/images/wheel...s_ch_ci3_l.jpg 8.5x19 Offset: 35mm 19x10 Offset: 20mm Are they ok for Z4 M? Thanks! Last edited by Gabri343; 02-21-2008 at 03:01 PM.. |
02-22-2008, 09:51 AM | #2 |
Rep 4,365
You should post in the Wheels/Tires forum... I am sure it would get more replies... and you would also be following forum guidelines
2007 Z4 3.0si Coupe 6 MT Black Saphire Metallic PP SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide Denim Black V&H Tune 2021 BMW x30i Phytonic Blue Metallic Fully loaded |
03-14-2008, 05:49 PM | #3 |
Rep 1,604
If my calculations are correct the front wheels are within 1mm of the OEM wheels' fitment while the rear wheels are less than 3mm from the OEM wheels' fitment so you should be ok.
OEM: Front: 8*25.4/2 + 42 = 143,6mm Rear: 9*25.4/2 + 30 = 144,3mm Your wheels: Front: 8.5*25.4/2 + 35 = 143,0mm Rear: 10*25.4/2 + 20 = 147mm Cheers. |
04-09-2008, 10:28 AM | #4 |
Rep 12,565
i've been sweating ch's in 19 for a long time, but way too expensive. and nobody has a used set =T
04-09-2008, 11:08 AM | #5 | |
Rep 11,667
Use this calculator to estimate effects of offsets & wheel size. 10" ET20 are VERY aggressive & will likely rub A 10" et20 wheel will EXTEND out an extra 34mm!!!
04-12-2008, 04:27 PM | #6 | |
Rep 613
06-18-2008, 04:32 AM | #7 | |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
