      07-29-2014, 09:41 AM   #1
mcoupe5/6
mcoupe5/6's Avatar
Drives: 08 M Coupe
Hi all,
Seems it's time to replace my front pads and rotors, and i'm wondering if anyone has a good suggestion on where to purchase.
there seems to be plenty of helpful DIYs out there so changing them myself with some help doesn't scare me. i'm thinking of sticking to OEM unless there is a deal out there too good to pass up. any thoughts?
      07-29-2014, 09:52 AM   #2
2286
If you decide to with aftermarket, I really liked PFC Z-rated pads. Best prices I found at the time were OG Racing & Bimmerworld. If you want to stick to OEM, I would look at Tishcer, BWMPartsPro, or ECSTuning.
      07-29-2014, 10:45 AM   #3
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Stoptech pads unless you have a real love of brake dust.
      07-29-2014, 01:47 PM   #4
macsubie
Drives: 06 Z4 MC
For street use, I purchased my ferrodo street pads at autorock and they only cost me $120ish for F&R.
I think it's too much to put track/high performance pads for street use, don't want to kill the rotors that soon
      07-29-2014, 02:30 PM   #5
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
While I'm buying for the 3.0si, not the M, I've not found Centric/Stoptech brake pads and rotors cheaper than RockAuto.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      07-29-2014, 02:32 PM   #6
mcoupe5/6
mcoupe5/6's Avatar
Drives: 08 M Coupe
Thanks for the suggestions, ecs has a service kit with their own cross drilled and slotted rotors and hawk hps pads. Does anyone have experience with either of these products?
      07-29-2014, 03:07 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I have the ECS rotors and StopTech pads and shortly thereafter I have front shimmy under hard braking.
And I'm very easy on brakes.
Could be FCABs, they're on my ToDo list, but as of this writing, I wouldn't buy the rotors again.
I'll go back to stock next time.
      07-29-2014, 03:22 PM   #8
chickdr
Drives: 2006 M Roadster
I have Hawk ceramic pads and stock rotors. Love the decrease in brake dust, but the pads are noisier than the OEM's were.
      07-29-2014, 08:03 PM   #9
jophish17
jophish17's Avatar
58
Drives: Z4MC
Getbmwparts.com sells OEM rotors and currently has a discount.. You could get all 4 corners for under $800
      07-29-2014, 09:17 PM   #10
wasupdu
wasupdu's Avatar
Drives: Z4 3.0, CLS63 AMG
I aways order from autopartswarehouse.com or rockauto.com and have been pleased. Fast shipping too. I just ordered EBC brake pads and new sensors from Auto Parts Warehouse and they arrived in 3 days.
Make sure you order sensor cables if the warning light is displayed, otherwise you're good to go.
The brake pad install was a piece of cake, but the sensors were kind of a pain. I don't plan to keep the car much longer, otherwise I would've just tied off the sensors.
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
      08-01-2014, 11:13 AM   #11
mcoupe5/6
mcoupe5/6's Avatar
Drives: 08 M Coupe
So if the warning light is not on, do i still need to replace the sensor?
      08-01-2014, 11:54 AM   #12
Karacticus
Karacticus's Avatar
I've found it good to have spare brake sensors on hand, at least if you want to retain the function.
You won't find out until you pull them whether or not they are going to fall to bits once removed. It doesn't usually happen, but sometimes it does.
2007 3.0si Coupe
