      05-08-2018, 11:30 AM   #1
wyshyvanuk
Drives: 2008 Z4 MR
Goof Off
Question: Will Goof Off Pro Strength Super Glue Remover dissolve the clear coat from your wheels?
Answer: YES!!!! ARRRRRGGGGGHHHHH.
Tried to remove leftover wheel weight adhesives and found out the hard way. I'm guessing that one of the other Goof Off products would have been a better choice.
Pardon me while I search for paint color and wheel touch up procedures.
      05-08-2018, 04:32 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
I did the exact same thing.
Luckily, I had a feeling it might happen, so I chose a spot deep inside the barrel to try first.
The only thing I've found so far that safely removes leftover wheel weight adhesive is fingernails.
      05-08-2018, 06:35 PM   #3
3002 tii
3002 tii's Avatar
Drives: E85, E90, F25
I’ve used bug and tar remover on some of the worst adhesive residue and it came off pretty easy, didn’t see overly harsh neither
      05-08-2018, 10:36 PM   #4
wyshyvanuk
Drives: 2008 Z4 MR
Thanks, guys. Is there an actual paint code/name for the paint on Z4 M wheels. I've seen some posts that indicate that its not the same as the non-M. My concern is that, if I give the wheel to a professional (Dent Wizard Wheel Repair in Phoenix), that they won't be able to match. Thanks, again!!
      05-08-2018, 10:53 PM   #5
scrammer
scrammer's Avatar
Drives: 2015 X4 35i...2007 Z4M-R
... fingernails and WD40 worked for me!
Current: Z4M-R & X4 35i-M sport
Past: E92 M3 ZCP Frozen...E92 335is...E90 M3...X5 4.8i...E46 M3 Cab...E46 M3 ZCP...E90 330i...E46 M3
StickMon456.50
      05-08-2018, 11:55 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm used to using WD40 to lubricate stuff, but I'm just learning it's worth to clean stuff after using it successfully to clean year old ink off my whiteboard at work.
Used it again recently to clean some goo off my garage floor.
      05-09-2018, 08:48 AM   #7
wyshyvanuk
Drives: 2008 Z4 MR
Will try WD-40 this afternoon. It won't even require a trip tp Ace Hardware. Thanks!!
      05-10-2018, 10:17 AM   #8
wdb
dances with roads
wdb's Avatar
Drives: 2007 Z4MC, 2007 3.0si Cpe 6spd
WD-40, some elbow grease, and repeated applications has worked for me for adhesive removal. I've also used citrus-based "goof off" type products in the same fashion with similar results.
      05-11-2018, 06:17 AM   #9
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
I use lighter fluid. It is an amazing adhesive remover and have never seen it attack any surface.
StickMon456.50
Finnegan441.50
      05-16-2018, 07:02 AM   #10
SaltyNC
SaltyNC's Avatar
341
Drives: 2006 BMW Z4M Roadster
3M Adhesive Remover in the aerosol can works great, too, and it doesn't harm paint/clearcoat. I bought it to remove a clear bra, and have been using it for all sorts of adhesive removal jobs since then. Good stuff.
Salty
wdb811.00
      05-16-2018, 08:38 AM   #11
wyshyvanuk
Drives: 2008 Z4 MR
Used the WD-40 to loosen the wrinkled M badge on the engine cover prior to flossing. Worked well. Thanks!!
      05-16-2018, 11:59 AM   #12
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
Wd40 on everything glue related.
