02-10-2016, 06:22 PM | #23 | |
Mechanical Engineer
96
Rep 1,025
$40 is cheap insurance to ensure you won't have to pick up a whole alternator in the future ($375 for a respectable rebuild, a few hundred more for new OEM). Anyone else who's mileage is getting up there should consider buying one of these while they're still available. |
02-10-2016, 09:43 PM | #24 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
02-11-2016, 09:16 AM | #26 |
Rep 1,107
Great find indeed! Do folks think it makes sense to proactively change out the voltage regulator at about 80K miles say? Does a voltage regulator going bad shorten the life of an alternator (we've confirmed it does shorten the life of a battery, right)?
02-11-2016, 11:32 AM | #27 |
Mechanical Engineer
96
Rep 1,025
02-11-2016, 12:28 PM | #28 | |
Rep 870
Crankshaft position sensors, oxygen sensors are also common failures. Salty
02-11-2016, 04:17 PM | #29 |
636
Rep 3,124
TPS (2)
Full set of O2 sensors EGT sensor MAF Coil (1 new + 6 that were working when I replaced them at 80k miles) Both belts CPV O-ring And, of course sacks of hardware: Front and rear single use reinforcement plate bolts Assorted plastic push-pin rivets Door card pins (white and yellow) Sack of body nut clips and associated screws Copper hardware for exhaust Crankshaft position sensors sound like a good thing to add.
02-11-2016, 09:23 PM | #30 | |
Rep 758
http://www.rowand.net/Shop/Tech/Alte...atorTheory.htm
Top Down 365
02-12-2016, 08:49 AM | #31 | |
Rep 1,107
- Crankshaft position sensors (are there Camshaft position sensors on the S54?) - Belts (at 50,000 miles) - Cooling system -Rad., exp. tank, hoses (at 80,000 miles) - Voltage regulator (at 80,000 miles) - Coils- bad coil can damage cats (at 80,000 miles) - Fuel pump (change at 100,000 miles) - Alternator (change at 100,000 miles) - What else? My fear as the car accumulates more miles is getting stuck on the side of the road far away from home. |
