      10-30-2010, 05:15 PM   #45
BAK613
Drives: Z4 M Roadster (E85)
Originally Posted by RickC View Post
One thing worth a try (works for me) is to turn the key to the point just prior to the engine cranking but allowing the fuel pump to start and prime for about 5-10 seconds then turn to start. Having the fuel pump started and primed gets rid of most of the dip for me
I haven't driven the car since last week. So this afternoon I followed your recommendation. Turned the key to on, did a slow "five count". and the engine started with out any dip. Went up to about 1200 and then settled nicely at about 1000 RPM.
Bruce
      03-25-2018, 09:10 PM   #46
Diesel_d66
Drives: '07 MR
I just got a 07 MR and this morning after a few days of sitting the car started and the revs dropped and stalled. After restarting the revs dipped and rebounded to around 1200.
Also is normal idle at operating temp around 1k?
      03-25-2018, 11:18 PM   #47
StickMon
StickMon's Avatar
Drives: 2006 MR
Yes and mostly yes.
Worse when it's chilly.
You learn to give it a tiny bit of gas 1 second after starting to help it thought the dip.
(Thanks to Salty for this tip. I always cover the gas pedal now after starting in case it needs a little help.)
Nominal idle when everything is up to temp is 870.
I get anything from 850 to 950, but most often 870-900.
      03-26-2018, 01:14 PM   #48
Diesel_d66
Drives: '07 MR
Thanks Stick, I'm actually more concerned about normal temp idle. Mine seems to be around 1k. Anyone else around the 1k point? or are most M zeds around 800-900?
      03-27-2018, 09:56 AM   #49
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
My idle definitely settles below 1K once warming/warmed up.
      03-28-2018, 03:57 PM   #50
Diesel_d66
Drives: '07 MR
I took it for a spin and wash last night and give the idle a closer look and looks like mine is also below the 1k line.
      03-30-2018, 11:25 AM   #51
Clearancediver
Drives: 2004 Z4
Has anyone considered that the start up dip issue indicates a fuel filter needing to be changed. Possible explanation for having to wait for fuel pump to pressurize the fuel system... once I changed mine the pressurization cycle was near instantaneous compared to prior filter change pressurization cycle.
Dirty filter causes a number of issues with startup in a car...
Given that the filter is internal to fuel tank it's not something that gets changed in routine maintenance. The saddle fuel tank containing the fuel pump/filter needs to be drained to do the change...
Sent from my smart phone...
      03-30-2018, 12:27 PM   #52
schwank
Drives: 06 z4 m coupe
Mine has done this since 2006
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
      03-30-2018, 12:34 PM   #53
ried
ried's Avatar
Drives: F31, F80
This happened on my previous M Coupe. I'm not saying this is the cause, but it coincided with the dealer accidentally leaving the crankcase breather valve disconnected from the valve cover after a service appointment. This resulted in a little oil splashing up onto the hood, of course, but the most noticeable side effect was the RPM dip upon cold start. I reconnected the crankcase breather valve, cleaned up the oil, and didn't have the issue again.
Correlation does not equal causation, of course, and your mileage may vary.
