      03-31-2018, 02:33 AM   #1
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
2 hard tops on ebay - 10 hours left!
One crazy looking carbon fiber hardtop:
https://www.ebay.com/itm/Bmw-Z4-M-Ro...xatoCb&vxp=mtr
Plus this Z4 with a hardtop included:
https://www.ebay.com/itm/2003-BMW-Z4...daT9~-&vxp=mtr
If you're local you could probably buy it separate from the car.
      03-31-2018, 02:41 AM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
That first hardtop is from a company called D Moris.
Too bad that hardtop turned out so ugly, because when they presented the drawings for it (artist impression) it looked awesome.
      04-02-2018, 11:07 AM   #3
RossBMWZseries
First one sold already for about $2,300
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      04-06-2018, 10:49 PM   #4
Lucky1
Drives: '08 128i Coupe SGM 6MT
What is the appeal of getting a hard top? I've seen a few threads in various forums asserting that it isn't really good to let your top completely soak in rain especially heavy downpour so I get that part. I also know its not good to put the top down right after it has rained and is wet as it will get mouldy. After a big rain you could remove the hard top and be able to drive with the top down right away since it was already down. So two reasons there I guess?
But I've also heard you don't want to leave the top down all the time for extended periods of time (as you would cause it to crease/wrinkle permanently and break down) which would making using the hardtop all the time a bit of an dicey business for the long run (kind of making winter use a no go right?).
Anything I've missed in my thought process on this one?
