01-20-2018, 06:12 PM | #1 |
Rep 193
Battery Replacement
Hi,
My Z4 07 3.0si needs a new battery so I picked one up from the dealer today. I searched everywhere on here and on Bimmerfest for a DIY guide to make sure I don't make any mistakes but haven't had any luck. If anyone can link it that will be great. Dealer parts said I don't need to register the batter or anything. Can anyone confirm? Do I just remove the negative then positive then install new one - positive then negative and that's it or is there something extra I need to do. I was going to wait until the spring but it was 65 today and it will be just as nice tomorrow! Thanks in advance. |
01-20-2018, 07:00 PM | #2 | |
Rep 1,798
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Waoudi23.00 |
01-21-2018, 02:18 PM | #3 | ||
Rep 193
It's a thin cable that attaches to the car. |
01-21-2018, 05:31 PM | #4 | |
Rep 1,798
Drives: E86 3.0si
01-21-2018, 06:49 PM | #5 |
Rep 193
Thanks! |
01-25-2018, 03:20 PM | #7 |
Rep 193
01-25-2018, 06:50 PM | #8 |
Proud E86M Owner
79
Rep 650
I am going to have to do this soon to my M Coupe,
Hopefully is not complicated for the ///M
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
01-26-2018, 12:28 PM | #9 |
Rep 1,991
01-27-2018, 12:25 PM | #10 |
Rep 2,869
Drives: Anything
All of the batteries that I had used have a vent hole on either sides, including 3 different AGMs. Some may have a plug on them that you will need to remove in order to install the vent tube.
01-27-2018, 04:00 PM | #11 | |
Rep 193
What happens if I don't have the vent plugged in? I drove it a few times. |
01-27-2018, 04:36 PM | #12 | ||
Rep 193
01-28-2018, 06:13 AM | #13 |
Rep 18,763
Let me ask a few questions. The new battery from BMW should have come with a little bag with a new elbow vent connector and a small plug; did your battery come with the bag of parts? There should be two holes along the edge of the top of the battery case one on each of the short sides. Depending upon orientation of the battery in the car, the vent uses one hole and the other hole is plugged. It's possible that the service/parts department opened the parts bag and plugged the hole in one of the sides already. Just make sure the other vent hole is plugged. Hopefully you bought OE BMW vent tube parts??? And did you orient the partition wall correctly? CarMax even screwed that up on my Z4
If you had to buy new vent line parts, then that tells me the original battery was replaced and whomever did the replacement didn't understand what the vent was for and discarded it, so you've been running "ventless" for however long you've owned the Z4 (and haven't died yet ). This was the situation I had when I bought my Z4 Coupe used from CarMax, the battery had been replaced with the wrong case size - so it just slid around and there was no vent line connected. Batteries are another case for "only trained BMW techs should ever touch a BMW"; well, or a seasoned long-time BMW owner. Something as simple as a battery install will get screwed up. No need to register the battery in the E85/86 Z4.
01-28-2018, 10:21 AM | #14 | |
Rep 193
How safe is it to drive ventless? |
01-28-2018, 10:37 AM | #15 | |
Rep 18,763
01-28-2018, 09:13 PM | #16 |
Rep 1,991
When you pulled the old battery the elbow should have come loose from the side of the battery and stayed with the rubber tubing. All you do is plug the elbow into the side of the new battery. Shouldn't need to order a new one.
02-24-2018, 01:28 AM | #17 | |
Rep 25
02-25-2018, 06:37 AM | #18 |
Rep 18,763
All car cabins are ventilated. The vent tubing is set up to prevent battery acid from spilling into the battery compartment if the battery over charges.
