      08-05-2014, 10:24 AM   #1
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Wrong oil?
So, I just noticed on the receipt that my Indy put in 5w-40 oil instead of 5w-30. Should I have them change the oil again or is this ok to use?
      08-05-2014, 06:40 PM   #2
ZMCoupe
Drives: 2007 M Coupe
You'll be fine as long as it is an LL-01 rated BMW spec synthetic oil. I always ran European formula German Castrol 0w-30 in my 330 ZHP. That being said I always brought my own oil to my mechanic because I preferred it over the 2 or 3 oils he had that still met the specs...
      08-08-2014, 05:59 PM   #3
mikl4
Drives: 2020 F22 230i xDrive
I believe that both 5W-30 and 5W-40 are recommended viscosities for the 3.0 si based on information provided in the owners manual. I changed mine recently and switched to Castrol Edge 5W-40 (BMW LL-01 rating) in the hopes that the slightly higher viscosity when warm might minimize resulting HVA noise - which I occasionally get from time to time when I haven't driven my coupe for awhile. Too early to tell if it's going to make any difference.
