03-14-2016, 12:40 PM | #1 |
Rep 139
is anyone from Apex still coming around? Need help on current ARC-8 group buy
Before anyone says anything I've spent hours and hours reading every thread on the internet about this, Literally.
I have an '07 Z4 M Coupe and am going to buy wheels in the current ARC-8 group buy but I really don't want the front wheels to have the shallower face profile. I've seen all the info suggesting that to get 9.5" wheels in the front you HAVE to run a bunch of negative camber (I'm buying FA 500 coilovers so will have camber plates), but I don't want to have to run so much that the tire wear on the front will be compromised. Part of the confusion is that in the spreadsheet that they have there's apparently one guy running 9.5" wheels on a stock setup with no rubbing. I don't mind the idea of carefully rolling the fenders too. I guess it begs the question of what's the most camber you can run and still get even tire wear and will that be enough? I do plan on lowering the car too. I do not track the car at all, btw. TIA |
03-14-2016, 02:27 PM | #2 |
Rep 1,443
I think I'm running -2.9 degrees with no rubbing on that setup. Also, on coilovers with camber plates and a "functionally low" ride height. Not sure any of that is really helpful though. Good luck in your search. The guys at APEX are pretty great about helping everyone out.
03-14-2016, 03:19 PM | #3 | |
Rep 139
How's front tire wear? I suspect at that camber you only get half the life out of the tires since the inner edge is gone pretty quickly?
03-14-2016, 05:10 PM | #4 |
Rep 1,443
I don't drive my car all that often unfortunately. Last I checked the wear was pretty close to even across both fronts but my service schedule and summary are on a different laptop so I'm not sure how many miles they have on them. Probably not more than 5,000 so not enough to see just how serious the uneven wear is.
Edit: I have just shy of 7,000 miles on my tires and no measurable difference between inner and outer wear.
03-15-2016, 12:35 AM | #5 |
Rep 404
Tire wear due to negative camber is a very misunderstood topic. 95% of the time that the inner edge of a tire wears before the rest, it is actually a result of tow wear.
You will be fine running up to -3 degrees of camber front. Just make sure to get an alignment such that toe specs are within oem range. Out of spec tow will chew threw tires in 2k miles. A properly aligned set up with even -3 degrees of negative camber should be able to last 10 times that amount, depending on how you drive, where you drive, and the tires your choose. |
03-15-2016, 01:17 PM | #6 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
DaveJB, I was in your shoes a few years ago, I initially pulled the trigger and went with a set of ARC-8s that I absolutely loved except for the front flat rim profile : http://www.zpost.com/forums/showthread.php?t=525150
When Apex announced the launch of the EC-7s with more sizes I jumped on the first group buy and purchased those. The EC-7s have 3 profile sizes, and I was able to get Profile 2 fronts and Profile 3 rears by going with the following sizes and didn't run into any clearance/rubbing issues. http://www.zpost.com/forums/showthread.php?t=859061 F: 18 x 9 ET 31mm R: 18 x 10 ET 25mm
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
03-15-2016, 01:27 PM | #7 |
Rep 139
Yeah, I think I've come to the conclusion that I'm getting the wheels I want and I'll do what it takes to make 'em work. Yesterday I just paid for the Fortune Auto 500 coilovers (with Swift spring and the radial bearing upgrade) and I'll roll the fenders if I have to.
I can say that the cars I've seen with the ARC-8 wheels with 9.5" wheels in the front look seriously bad-a$$. I'm no rich guy but ugh, $1200-ish for the wheels, $1575 for the coilovers and I'll need two back tires at about $400. Don't tell the wife! |
03-15-2016, 01:57 PM | #8 | |
Rep 139
Admittedly I'm a bit skeptical that -3 degrees of camber won't increase tire wear but I do agree that toe is a huge issue.
03-21-2016, 02:27 PM | #9 | |
Rep 139
