      08-18-2010, 09:09 AM   #1
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
UUC tranny mounts with cups
Has anyone had a hard time putting in the 4 bolts holding the engine mount bracket after replacing with UUC tranny mounts? It's not that I can't get my fingers in between the bracket and the exhaust pipe---the holes just don't line up anymore.
I have the black neoprene with the cups and I cannot get 1 of the four bolts connecting the brace to go back into the hole. I think the aluminum cups make the transmission bushing a little too wide (pushes against the transmission) and the transmission brace bolts can't line up completely with the holes.
Has anyone had this problem? I'm thinking about replacing the offending bushing with a stock one and calling it a day. I spent almost two hours trying to align one of the bolts.
      08-18-2010, 03:10 PM   #2
3002 tii
3002 tii's Avatar
2278
sorry mine went in fine w/o the cups. why not install w/o the enforcers and send those back?
Follow for latest mods
      08-18-2010, 04:20 PM   #3
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
I'm going to try to get the cups off the enforcers tonight...man, they're stuck in there tight.
      08-18-2010, 05:13 PM   #4
franco209
Drives: 2010 M3 Coupe
Mine went in fine also with or with out the cup. May be jack up the tranny a little bit?
      08-18-2010, 09:46 PM   #5
jbh
jbh's Avatar
18
Drives: 2007 Z4M
See my PM I send you, put the brace on first (loose) and then install the mounts, cup side down. Its tought to get the top nuts tight but a small socket wrench makes it work out ok.
      08-19-2010, 02:50 PM   #6
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Thanks for all your help. I ended up removing the cups and installed with the aftermarket neoprene bushings---didn't feel like messing with it anymore.
Search this Thread:
Advanced Search
