      12-02-2017, 08:40 PM   #1
apexhittinbull
Drives: E85 M
Lacking Stowage lock in Roadster
I am the 2nd owner of the car and I'm not sure if PO removed it.
I do not have the center stowage lock (between the seats under the storage switch cover) nor the Tongue at the end of the soft top.
I can't figure out how these to lock into or unlock with power top, as my hydraulic motor is out
Car build date is 05/30/06, am not sure if later year cars are deliberately made without them due to squeaking noises.
#3 in the picture (Tongue at the latch)
Does having these two make the top flush and locked safe when the top is down?
Are these really necessary?
      12-03-2017, 02:37 PM   #2
Huz-Z
Huz-Z's Avatar
I understand that for 2006 and later roadsters that part was deleted from the design. Folks -feel free to jump in if I’m wrong.
      12-03-2017, 06:14 PM   #3
apexhittinbull
Drives: E85 M
My M$ Question as well.
      12-03-2017, 09:27 PM   #4
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
I think that is correct. I have the same car as you, and my build date was 3/2006, and it doesn't have that part. I think there is a thread somewhere about eliminating a squeak in that area, and earlier Z4's had it, but post facelift cars don't.
Salty
      12-05-2017, 01:50 AM   #5
Beedub
feb 06 build Z4M, it doesnt have this part in my car!!
      12-05-2017, 05:30 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
As for the center storage compartment lock, I am the 2nd owner of the car and the PO unplugged it.
I decided to leave well enough alone.
I'm guessing they had it get stuck, as well as the gas fill flap.
Lock's gone off that too.
Neither one will stop a determined thief. Just make them cause more damage.
