      04-05-2015, 10:41 PM   #1
markZ4MC
Drives: Z4MC
How do I fix this?
Do I have to remove the entire bumper? I had a run in with a curb...
      04-05-2015, 10:52 PM   #2
Honorebel
Honorebel's Avatar
Drives: 2008 Z4 M Coupe
Is just the black fender clip broken or did the bumper tear too? If its just the clip you just need a new one and it will snap right back together.
      04-05-2015, 11:07 PM   #3
markZ4MC
Drives: Z4MC
Thanks for the reply. Looks like just the clip. Do you know what the clip is called or ideally the part?
      04-05-2015, 11:58 PM   #4
jeebus87
Drives: '11 atacama yellow Z4 35i
Just bought the same thing about a week ago. Here's the part number for R side bumper clip: 51117165180
http://www.ecstuning.com/ES74723/
      04-06-2015, 12:04 AM   #5
markZ4MC
Drives: Z4MC
Wow thanks so much. Was it hard to replace/repair?
      04-06-2015, 12:21 AM   #6
Honorebel
Honorebel's Avatar
I had to replace one as well it's not too difficult. You will need to break the old one off the fender and simply snap the new one on. I had my bumper off when I replaced it but that's because I was doing some other work. I think you might be able to just replace the broken clip and snap the bumper back into place without doing much else.
      04-06-2015, 03:02 AM   #7
jeebus87
Yep. As above. If there are any remnants of the old bumper clip, you'll have to remove it and then just snap the new one on. I basically had to destroy the old one to get it off. Pretty simple and self-explanatory.
      04-13-2015, 11:04 AM   #8
markZ4MC
Drives: Z4MC
Thanks guys. Ordered, I'll let you know how it goes.
      04-13-2015, 11:42 PM   #9
jeebus87
Just fyi, you will have to use some force. I wound up using pliers to break apart the top piece of the plastic bumper clip. It won't come out in one big piece. The new one snaps right into place and re-installation is a breeze.
