01-02-2012, 09:26 PM | #1 |
Rep 4,531
I have a feeling my hood adjustment is off.
Call me paranoid. But I don't think my hood is lining up correctly with my front bumper.
I've been looking at alot of shots of cars, and mine just doesn't look right IMO. Pictures are attached. You can see the white lines from the hood to the bumper aren't uniform, and are "broken" so to speak. The two latch points match up, but then the hood sort of starts heading up and appears to not match up with the bumper at all. Am I looking at this weird? My dad and I both noticed it, but no one else has ever mentioned it, call me being OCD. The odd thing is, since the latch points match up, can this even be adjusted if I took it to BMW? I'm still under CPO, so it would be a measly $50 to get it done...and I still need to get my rear trunk sensor looked at...but that's another issue. So, what do you guys think? *The best shot IMO, The hood latches match up, and you can see the gap increase as it gets to center*: The mismatched lines: Right line distortion: So, am I crazy? |
01-02-2012, 09:32 PM | #2 |
Rep 1,351
Drives: in Anger.
Yup! Better go invest in a self buckling straight jacket.
But actually, I have noticed the same issue with mine and I think it is just a visual thing due to the curve of the front of the car.
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
01-02-2012, 10:24 PM | #3 |
Rep 820
Drives: 2007 Z4MR silver grey
............ and I though I was bad
John |
01-03-2012, 06:24 AM | #4 |
Rep 4,531
01-03-2012, 06:50 AM | #5 |
is a Texan
49
Rep 387
I see the little gap you speak of, but don't see how that'd be an allignment issue over just a production flaw.
...it might be before 8 AM, but I suggest going and sipping a beer, Kyle Just have the dealer look at it when you take it in for the hatch sensor or something else, I bet they look at it and laugh for free! (or say they can fix it and take your money).
- Jake |
01-03-2012, 07:08 AM | #6 |
Rep 2,138
Drives: Me
If you really want to screw up and cause way more issues than you really want to deal with, start playing with your hood adjustments when you don’t need to.
The issue is not the hood but the plastic bumper fascia. You can fix this yourself in 10 min. by loosening the top mounting strip for the bumper fascia and move it in or out and tighten the torx bolts backup. BMW will tell you the gap is within spec. and most likely not do anything about it. The missing washer cover is more of an issue than a 1/16" gap mismatch. |
01-03-2012, 08:14 AM | #7 | |
Rep 4,531
Thanks for the tip on the bumper. I'll look at that in the spring. The missing washer cover has already been taken care of. It broke thanks to good ole crappy plastic. Fuse 40 will be pulled |
01-03-2012, 08:21 AM | #8 |
Rep 844
Has the car ever been in an accident? A lady backed into the front of mine and bent the hood ever-so-slightly. The damage was extremely minor but nonetheless, the hood was bent just enough that it looks exactly like yours. Prior to the accident, my hood was even and matched the front bumper perfectly. It bothered me at first but now I don't even notice. Most others will never notice either.
01-03-2012, 08:27 AM | #9 | |
Rep 4,531
Car was bought last March. Checked through BMW service records, carfax...everything and nothing was shown on the paper. I additionally was able to track down the PO (the car was For Sale at a Lexus dealership) and talked to him personally. Car was always garaged and covered, never drove in rain. Needless to say, I don't think it was. |
01-03-2012, 09:19 AM | #10 |
Imola Lover
26
Rep 749
Check your buffer stop ejectors. Common failure point from people slamming their hoods.
01-03-2012, 09:32 AM | #11 | |
Rep 4,531
I'll take a look when I get home. Last edited by Kgolf31; 01-03-2012 at 09:39 AM.. |
01-03-2012, 10:30 AM | #12 |
Rep 262
I agree with with Shipkiller, I'd look at the bumper first and see if you can adjust it out there. If not, I'd leave it alone. This will turn out to be a prime example of shoulda, woulda, coulda, didn't........SH*T!
01-03-2012, 10:35 AM | #13 |
Rep 784
Drives: 2011.5 E90 M3
The buffer stop ejectors are on the outside of the hood, so it could be that the hood is too low in those parts compared to the center.
01-03-2012, 12:46 PM | #14 |
Rep 820
01-03-2012, 04:39 PM | #15 |
Rep 2,138
Drives: Me
Also, BMW has shims that go in between the chassis and bumper fascia to raise that portion of the bumper just a bit if needed. I forgot that one....
My M has two shims on the left side. None on the right. |
01-03-2012, 06:45 PM | #17 | |
Rep 4,531
01-03-2012, 07:15 PM | #18 |
Imola Lover
26
Rep 749
01-03-2012, 07:28 PM | #19 |
Rep 2,138
Drives: Me
Just in case you don't know what I mean or have never seen these shims, here is a pic.
The silver shim is circled in RED. |
01-03-2012, 07:31 PM | #20 |
Rep 2,866
Thanks for the picture. Do you happen to know the part number for those shims? My car can definitely use them in the same locations!
01-03-2012, 07:56 PM | #21 |
Rep 2,138
Drives: Me
I don't have a P/N but I have seen these types of shims in most autobody shops. I am going to assume any type will work.
The BMW shims are made from aluminum. |
01-04-2012, 10:56 AM | #22 |
Rep 2,138
Drives: Me
I just arrived back from Harbor Freight. I needed a metric tap/die set....
I also saw a box set of those exact shims. $9.00. All different thickness's in the set. |
