09-24-2020, 10:35 AM | #3 |
Rep 779
Also they have these listed, thats an insane price and probably beam pattern isn't DOT or even tested. not worth the trouble to get any aftermarket led, especially from ali express. I wouldn't even list these as viable option
https://www.aliexpress.com/item/32824253860.html
-Roranji
09-27-2020, 11:18 PM | #4 | |
Rep 2,552
Gotta love the "LED angle eyes drl" I guess the shine to the side BTW, they're HID, not LED beams |
09-27-2020, 11:19 PM | #5 |
Rep 2,552
dup
10-01-2020, 09:04 AM | #6 |
Rep 779
Yes because no one really makes them.. car is too old, LED was not widely used back then in headlights... its not till recently LED became popular.
Thats why you have retrofit forums, its going to be DIY or cheap aftermarket hacks
-Roranji
10-08-2020, 06:21 PM | #7 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
For over a year I've been running DDM Tuning Saber LED (H7, 50W). They have been an improvement over the aftermarket HIDs I had installed before.
The LEDs are a drop-in solution (replacing the stock halogen bulbs) and required minor fitting of the bulb holders. It was a bit of a squeeze but everything fit and I haven't had any issues with them at all. I'm not sure if it would be the same process with a stock bi-xenon setup. Then again, if I had the stock bi-xenon setup I probably wouldn't convert to LED.
2008 Z4 3.0si Coupe
rsutoratosu114.00 |
10-09-2020, 10:32 AM | #8 |
Rep 208
Drives: 08 Z4 M Coupe
You can get a pretty substantial upgrade with retrofitting LEDs for the running lights and new bulbs. Pungo did my LED upgrade and they match perfectly with Osram Xenarc Cool Blue bulbs. The actual light is closer to white than blue and they're much better at night than the stock bulbs.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
10-09-2020, 04:21 PM | #9 | |
Rep 433
10-10-2020, 02:30 PM | #10 |
Rep 208
These are the bulbs I used:
https://www.amazon.com/gp/product/B0771VZ353/ For the rest, you'd have to see if Pungo (he replied earlier in this thread) will reveal his secrets. Or send him your lights, turnaround is pretty quick.
