03-02-2019, 02:04 PM | #1 |
Rep 14
2007 Z4M, where is audio-in jack
Hi everyone,
I've just acquired a Z4M. It's got the nav system. It has aux as a input source but where might I find the audio in jack? I suspect it doesn't have one. I see an after market kit. any recommendations? |
03-02-2019, 02:19 PM | #2 |
Rep 528
Drives: E86 Z4MC; E92 M3
If installed from the factory it's under the climate controls above the ashtray.
If installed afterwards (an accessory kit is/was available) it'll likely be in the ashtray.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
03-03-2019, 12:14 PM | #4 |
your average JAMF
3117
Rep 4,095
'06's don't have one, but '07's & '08's came with it as standard, as shown above. At least in the NA market, not sure about ROW.
'21 M2 Comp
'19 Golf R |
03-03-2019, 12:40 PM | #5 |
Rep 528
I thought this too - my '07 Z4MR had it installed factory. But then I got my '06 Z4MC and it's also definitely factory installed under the dash and not in the ash tray. Must've been a running change.
03-06-2019, 12:47 PM | #6 | |
I plead the 5th.
523
Rep 1,519
I still need to retrofit this plug someplace. I think this may be the only reason I wish I had an 07-08 rather than 06 haha.
-Matt
03-06-2019, 01:02 PM | #7 | |
Rep 528
In speaking to mtnbkr I believe his had AUX-in in the factory position as well, and our cars have sequential VINs and both 2006's.
03-06-2019, 09:00 PM | #8 | |
your average JAMF
3117
Rep 4,095
Just today I was out cruising with SiriusXM streaming through my iPhone, connected to the aux port via a Lightning-to-aux cable. I ASSume the aux cable has to contain a DAC - that's really the only place the digital-to-analog conversion could be taking place. I have the streaming quality set to max in the Sirus app, which is supposedly 320kbps - or about 6-8x better than the. satellite stream. It sounds fantastic. Unlimited data on my T-Mo plan so no worries there. Important to me because I live in the sticks, and there are literally zero FM stations within range that I want to listen to. This is the cable I'm using - $18.49 from Amazon: https://goo.gl/MRPTDo
'21 M2 Comp
'19 Golf R |
03-06-2019, 11:42 PM | #9 | |
Rep 2,868
03-07-2019, 10:53 AM | #10 |
Rep 623
I notice the same music on a MP3-CD has a deeper more rich sound than the same MP3 on my iPod with the AUX cable. The bass is no where near as present.
Steve |
03-12-2019, 11:21 PM | #11 | |
636
Rep 3,124
Hopefully it will keep working for you. I have 2 similar gizmos at home that are charging docs with 3.5 mm jacks. Thought one of them broke, but on a whim I tried the other. Same thing. Apparently Apple updated something in iOS 12.x. Now my iPod plays for 10 seconds and then launches into fast forward. Edit: Update: Just updated from iOS 12.1.1 to 12.1.4, and now my docks work again. Beware iOS 12.1.1.
04-03-2019, 10:11 PM | #12 |
Rep 278
The only thing I have disliked about the car is not having a Bluetooth or aux port. What do you guys recommend for aftermarket options?
Good things may come to those who wait, but only what's left by those who HUSTLE!"
-George Washington |
